Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
Ram memory With both ram memory chips, the secondary one overheats and causes the system to reboot. I replaced both with new chips and same thing occurs. I am now running a single chip of 1gb without problem but there must be an answer for why it doesn't work with 2 chips in place.
Okay, I have a stupid question, the more powerful the chip the hotter it runs. It could be the second slot will not work with a 1 gig because of heat issues and ventilation?
I have the same problem, with 2 one gig chips. I am going to try to replace the easy access slot with a 1/2 gig chip. I'll let you know.
Cheers,
Paul
Posted on Aug 15, 2008
SOURCE:
Dell Xps M1330 New motherboard failure.
When you removed or put in the CPU and the Heat Sink did you put a fresh coat of Thermal Paste on them? If not that is like metal touching metal and it will short out when you try to boot up.
The other problem might be that either one of your memory chips is bad or one of the slots on the board that holds the memory is bad.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 31, 2012 | Dell XPS M1330 Notebook
Computer does not start . When powered up it give message on monitor screen " Parity errorsystem halted" . Please suggest the solution for it?
@mahesh_0552
Parity Errors are caused by faulty RAM or memory chip. This occurs when data is leaked when it's passed thru the RAM (usually during POST - Power On Self Test - this is the mode when the computer boots up and initially check for hardware components connected to the computer). In this case, you need to replace your memory.
More info at http://support.microsoft.com/kb/101272.
Sep 06, 2011 | Computers & Internet
I have an Acer Asper 1 notebook that had some issues during a regular scan, fixed problem and had virus protection. Went to start pc it loaded a black screen and said media problem, and hard drive problem....
If there is no display, try resetting your bios or cmos. Then check by turn it on, if it's still the same check your system ram, unplug your ram and clean the pin using hard eraser then brush it using small paint brush. In case you have two ram check 1 by 1 plugging onto your dimm slot. Causes of no display are defective memory, defective motherboard chipset due to overheat and defective LCD. Have a good day!
Dec 07, 2010 | Computers & Internet
Error 0X0000007A (0XC07C1AB0, 0XC000000E, 0XF8356642, 0X0A1F0860) When i switch on my PC i get this blue screen error report. i don't know what this error is. please give me the recovery suggestion. Thanks...
How To Fix This Error
Error Message:
Stop Error 0x0000007A (Kernel data inpage error) Translation:
This occurs due to a memory error from a faulty hardware device or virus. Solution:
If your system freezes during Operating System installation, make a note where the installation stopped. Often, you can narrow down your problem by knowing when the freeze occurs.
Frequently, installation freezes are caused by incorrect settings in the CMOS (complimentary metal-oxide semiconductor). The CMOS stores special configuration settings for your computer’s hardware and is used by the BIOS (Basic Input/Output System) when your machine boots. Your motherboard or system should have come with a manual that describes the CMOS settings. If you don’t have a manual, download one from your manufacturer’s Web page. To change the CMOS settings, press the keys as shown in your manual or on your PC’s startup screen (often DELETE, ESC, CTRL-ESC, or CTRL-ALT-ESC) immediately after you boot your computer. If you change any of the CMOS settings, write down your changes and keep them in a safe place. Then you can refer to the settings if you need to change them back or redo them if you reinstall or upgrade to a new version of Windows later on.
Incorrect CMOS settings for system cache memory and RAM may confuse the Windows installer and freeze the system. If your system freezes during setup, try disabling the system cache memory. If you are able to install the system after your CMOS changes, then you fixed the problem. If this doesn’t work, then try adding a wait state to (or slowing down the timing on) your RAM. (Wait states are periods where the CPU pauses while waiting for data from slower components.) Adding a wait state causes the computer to address the memory less quickly and often fixes unexpected freezing problems, black screens, or unprovoked reboots. After Windows is fully installed, use the new system for a while to make sure it is stable. Then, restart the system and change the CMOS settings back. If the system remains stable, keep the settings; otherwise return to the stable settings permanently.
Bad RAM chips or a boot sector virus can cause inexplicable freezes during installation. If you suspect your memory might be the trouble and you have extra RAM chips around, try the installation with the other chips instead. If you think you have a boot sector virus on your hard drive, then use a bootable CD-ROM or diskette to check and clean your hard drive using programs such as Norton AntiVirus (http://www.symantec.com) or McAfee VirusScan (http://www.mcafee.com).
Feb 11, 2010 | Toshiba Sattelite A105-S2051 Notebook
ASUS P5QL PRO memory problem
This problem occurs because of confliction between RAM memory frequency.
For that you must have 2 RAM with same memory frequency and same company chip .
Then it works fine with 2 RAM.
Let me know if you need further assistance.
Thanks.
Nov 03, 2009 | ASUS P5QL PRO Motherboard
P4 System with Intel D865GBF Socket 478 will reboot on shutdown
start with a minimum system. just enough to boot the machine. no nsound or modem or nic'sw unle3ss they're integrated. use all like memory.. preferably 1 chip. update the bios to the latest greatest version. speaking of which. what windows r u running? nt4, y2k , xp home, xp pro , xp enterprise, vista?
ne way attempt to boot with just the hard drive.. dont attach any other cables.. (floppy, cd. etc) if you can boot into the system add the other items to the system one by one rebooting each ntime with each new item. you'll find the device thats causing the problem..if it's a hardware issue. if it does the reboot
it may well be the os.. try safe mode... i know for example y2k and my p4 wouldnt let a diamond stealth s540 video and the creative labs pci 64 sound card be in the same system.. they locked it or blue screened it everytime.. or it'd reboot.. anyway..good luck..
May 18, 2009 | Tyan Tomcat K8E Motherboard
Mac keeps shutting off by itself
Hello, this is called a "hard reboot" and can occur because of faulty RAM memory (have you added extra ram recently?).
It can also come form a dead hard drive, or a dead fan, causing overheat
Apr 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computer never starts
You just Replaced 2 things that have nothing to do with your Issue...
You Need to check your RAM and Hard Drive....Reseat Your Ram and test it
Also Make Sure Your Hard Drive is correctly in its slot..
That Make / Model is known for having a Faulty Nvidia CHip... Which causes that rebooting... Not Sure If THats Whats Happening with yours.. But Look Into It... They Are Repairing These Boards due to Recalled Chips...
Try Removing Your WiFi Card and Your Hard Drive....Remove Your Battery as well.... Plug In AC Adapter and try to power on the laptop.....
Nov 17, 2008 | HP Pavilion ze4365us Notebook
Intermittently After Startup the PC Reboots Automatically
Did you do something that come up to that problem? Or does the problem just occur?
Oct 24, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
GA-EP35C-DS3R random reboots
Hi Buzznode,
First things first - once you have all the components properly seated (sometimes if a RAM chip or CPU heatsink/fan isn't quite right it'll cause those problems) clear the CMOS entirely. There should be a jumper somewhere near the CMOS battery - move it from the 1-2 seating to the 2-3 (with the system powered down) and count to ten. Move it back over and then try booting up again. If the problem continues, swap the memory chips. Otherwise repost once you've tried the recommendation.
Ben
Mar 07, 2008 | Intel Motherboard
Open Questions:
See all HP Pavilion zd7000 zx5000 zv5000 presario Questions
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
81 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
