TV won't stay on?
Press power TV come on for a few sound and turn off?
i have a Craig CTV2000 and the picture gets fuzzy then it turns itself off, called a television repair and they cannot find this model sooooo, what do i do
    Novelist:
    Scholar:
  • 149 Answers
Have you contacted the manufacturer yet in order to better assist you with a legit repair electronic place in your area?
I also goggled the model# since the manufacturer didn't pull it. It appears you have a UK 2001 model which would mean you are experience the collision between PAL and NTSC!! You might either not get audio otherwise you will get a scrambled audio sound which sounds like munckins then a distroted pixelated and zigg-zagg appearance consistantly on every screen. There isnt anything you can do with this since everything is broadcasted in NTSC in the USA and no pal unless you have a pal DVD player.
Do you have a pal DVD player that might work ok with this?
Let me know. Thanks.
Posted on Mar 31, 2008
  • Anonymous Mar 31, 2008
    btw, the different between pal and ntsc is a totally different speed between them which it just doesnt and never will work together.
SOURCE:
Why does my vizio tv only stay on for a few seconds before the picture goes fuzzy and the tv makes a very loud screeching noise and shuts itself off
Sounds like the power supply board has gone out. It can probably be replaced, but only by someone qualified to do so.
Oct 21, 2014 | Vizio L32 32 in. LCD HDTV
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
TV won't turn on
it is maybe power supply is damage,please check the fuse of power supply,if it is fuse is damage,you can change it.if fuse is ok,you can change power supply boards.when you find which boards is defective,you can search by pcb number on www.wisiny.com
Jun 05, 2013 | Craig CLC501 15 in. TV
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
36" tube tv. picture fuzzy and out of focus
It sounds like you may have a G1 intermittent short in the picture tube, which unless it is still in warranty would not be worth repairing.
Jan 02, 2007 | Philips 36PW9525C 36" TV
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
Ekse
