Question about Fuji FinePix Z5fd Digital Camera
Fuji Fine Pix Z5 battery won't charge
My camera works fine when the charger is plugged but the battery won't charge. I bought a new battery assuming that was the problem and it will not charge either. Also, the charging light does not go on on ther camera when the charger is plugged in. Any ideas?
My Finepix Z5 works fine when the charger is plugged into the camera but the battery never charges. After reading the post with the same problem, I'm not sure if I want to buy a new battery and get the same results. The charging light also does not go on when camera is pluged in and is charging, help
  • 6 more comments
  • PDeV Jun 10, 2008
    Our Fuji FinePix Z5 recently developed exactly the same problem. Works fine when plugged in, but goes off when unplugged. The battery is not the problem.
  • ededr Jun 24, 2008
    Fugi FinePix Z5 will not power on/off regardless if battery inside or with charger plugged in. Expect better quality from Fuji than what I have gone through
  • Anonymous Jun 30, 2008
    yeah wtf
  • lenny8149 Jul 28, 2008
    My Fuji Fine Pix Z1 is having the same problem. It will not charge in the docking station, the charge light does not turn on.
  • Anonymous Nov 27, 2008
    I plugged the charger in and plugged the charger into my camera, and it wont charge, nor turn on
  • Anonymous Feb 26, 2009
    my battry is a new one and it wont charg i plug it in the light goes on and the off it is really wierd
  • Anonymous Apr 17, 2009
    My problem is exactly the same.
  • Anonymous Mar 28, 2014
    I went to turn on my fine pix xp55 and it won't turn on at all I thought it was the battery so I purchased another one ,charged it and still won't turn on it won't do anything
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
Posted on Sep 26, 2008
Littlelily is right, I had the exact same problem; my camera wouldn't turn on when unplugged from the wall, and wasn't charging, and I thought that it was broken.
It turned out, as littlelily stated, that I actually had the battery in the wrong way around (embarrassing for a technician really :| ) ; you have to flip the battery so the left is now the right side and vice versa. NOT top to bottom, just a flip on it's Y axis (if it were standing with the shortest face as a base).
Posted on Jul 27, 2010
My sister's Z5 was having the same problem. I realized she had the battery in upside down. There are no guides on the battery to insure that it goes in the right way.
If the battery is in correctly, and it is still not charging, I would call Fuji to get it repaired.
Posted on Apr 12, 2008
Just got a fujifilm finepix and i dont know if it is charging with or without the light on. the light wont go on but my camera will turn and take pics while it is pluged in at the wall but when i take it out it doesnt work
Posted on Apr 15, 2010
  • sheryleej Apr 15, 2010
    its working now
The battery isn't in upside down. It works while plugged in, will turn on and take pictures but once I unplug the charger from the wall the camera won't even turn on.
I'm going to most likely send it in to Fuji but was hoping that Best Buy could do something since this is where I purchased it from...
Posted on Apr 16, 2008
2 Suggested Answers
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Camera won't charge
sometimes the charger can become loose in either the camera or the plug so try buying a new plug and if it still doesn't work then it is a problem with the camera and you will have to ask the people you bought it from
Jun 18, 2013 | Kodak EasyShare M853 Digital Camera
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
I Have a Fujifilm Finepix J37 that wont turn on, I assumed that the battery had run down so put it on charge and no lights came on, usually it lights up on the back of the camera when its charging! Faulty...
hmm i have the same problem with mine.i got a replacement battery and it worked fine for a few days but then went back to the way it was. so i'm thinking the problem is with the camera itself. how long have you had the camera for?
Sep 08, 2010 | Fuji Cameras
My camera, having worked perfectly for a year, failed
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 04, 2009 | Fuji FinePix S1000FD Digital Camera
My camera will not work with regular batteries
as far as it is working with re chargeable's then it is ok what is wrong with it , it needs more power i mean MAH so give it , to sell it go to ebay check the similar model price how much ppl are selling and post ur product
Feb 20, 2009 | Fuji FinePix A310 Digital Camera
Ni-mh
yes ther is no problem using Ni-MH batteries, as they do not have a memory effect they will be better (subject to your charger), you can get the Fuji Finepix NH-20 batteries (wj=hich are NIMH) here - Fuji Finepix F420 battery
Dec 26, 2008 | Fuji FinePix F420 Digital Camera
New memory card
Hi I have bought a new memory card, Olympus XD M 1GB. For my Fuji fine pix A330 camera, and I can't get it to initialise, or format properly, can you help me many thanks TRENA
Jun 03, 2008 | Fuji Cameras
Feb 22, 2008 | Fuji FinePix F20 Digital Camera
Rechargeable Battery won't charge
I think this is a general Fuji design fault in the camera circuitry. I have an older F455 which has exactly the same problem and I did the same - bought new batteries only to discover that didn't help. The only solution is to spend even more money for a stand alone battery charger.
Sep 07, 2006 | Fuji FinePix A340 Digital Camera
Fuji FinePix Z5fd Digital Camera Logo
4,717 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
