Question about Hotpoint TDC32 Electric Dryer
HotPoint Elec dryer heats up but doesn't dry
I have a Hotpoint electric dryer. It seems to heat up fine and as a matter of fact the top surface of the dryer is very hot to the touch. But the clothes never get dry. I mean after hours they aren't dry. Even the lightest weight items. It's almost like there isn't any air flow. Any ideas or suggestions?
Thank
Deb
  • 1 more comment
  • Deb62 Apr 01, 2008
    It is the crinkled up kind but kind of looks like metal instead of plastic. I moved the dryer after you told me this and it's working great now! Thanks so much, your my hero of the day :)
  • Deb62 Apr 02, 2008
    I surely will! Thanks again for your quick response and helpful solutions.
    Deb
  • misstryfixit May 09, 2008
    Hi I have a hotpoint condensor TDC30 and it heats up on the outside and the clothes feel warm but take hours to dry.I empty the water before each load and clear the filter but it doesn't make a difference. I would appreciate some tips
    President:
  • 1,314 Answers
Yes you have a vent restriction something is blocking your airflow it needs to be an open 4 inches all the way and clear describe your vent to me are you using plastic behind the dryer is it short or all mashed up don't move the dryer get a flashlight and look over the back like its sitting and describe your vent to me from the dryer to the out side if its plastic and looks like a python then you may have found your promblem
Posted on Mar 31, 2008
  • robert samples Apr 01, 2008
    well rate me it helps hon every time i fix something and don't get rated i lose points but listen for a moment the best way to do your drier vent is 4 inch pvc plastic drain pipe run it under your house and tie it to your floor joist put a 90 degree elbow on it and bring it up through the floor put a 4 inch hood on the out side then cut the connection hose only as long as you need to and hook it to the pvc and when you push the dryer back make sure its not mashed or folded over and you wont never have a problem otay-17
  • robert samples Apr 02, 2008
    hey your welcome thanks for helping it keeps me able to to help others
If that didn't work, what else could be the problem?
Posted on May 02, 2008
SOURCE:
MY HOTPOINT DRYER MODEL TVM560G AQUARIUS IS NOT DRYING WITH ANY HEAT
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Hotpoint Dryers
My hotpoint dryer doesn't heat up, it runs but the air is not warm to dry anything. Can you tell what is the problem?
dismantle the top and front covers,then test the heating element,high limit thermostat on the element housing,then,check the cycling and thermal fuse on the blower wheel housing for continuity
Mar 03, 2011 | Hotpoint TDC32 Electric Dryer
The Hotpoint Dryer shows sweat on the inside door and takes longer to dry the clothes. Marilyn
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 26, 2010 | Hotpoint Dryers
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
Dryer takes too long to dry
You my friend have a bad circuit breaker.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2008 | Hotpoint NVL333EY Electric Dryer
Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Sep 27, 2008 | Hotpoint NVL333EY Electric Dryer
Hotpoint t/d ctd40
my dryer doesn,t heat up & after a while the time delay,high heat & on off button flash.
Feb 11, 2008 | Hotpoint TDL14 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
811 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
