Question about Jenn-Air JGR8855BDS Gas Kitchen Range
Jgr8855bds range - oven problem
The oven will get hot when I do the self clean.
It is taking a really long time to get hot. 165 now and has been on for over half an hour
  • 109 Answers
That's too long, check to see if you have flame in the broiler section, i'm thinking not. see if your ignitor is just staying on without igniting burner, ignitors will produce that much heat in that amount of time. if no flame at butner, replace ignitor.
Posted on Apr 01, 2008
What may cause the oven overheating during self clean
well last time I checked the self clean went to around 600 degrees . has to to burn off the stuff burnt on inside . and YES outside gets really hot .
Aug 28, 2014 | General Electric Ge Stove / Oven / Range...
How do I use self cleaning oven
typically the "self-cleaning" part is automatic, and all it really does is get so hot that it burns all the crud off of the surfaces. Check owners manual for complete "how-to" use options for your oven.
Apr 20, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Describe how to access the self cleaning feature on the accubake oven and how long does it take?
Press the "Auto Clean" or "Precise Clean" button depending on the control type of your range. Then press start. The oven should lock and start the self-cleaning cycle. The cycle is usually 3 hours from start to finish and cannot be stopped once it has started heating. The range gets extremely hot and causes the inside of the oven to act like a catalyst to burn the grease. It will create smoke and odor depending on how dirty the inside of the oven is. Make sure to leave the exhaust fan on above the range to remove some of the heat. And definently do not do the cleaning cycle on a hot summer day!
Feb 19, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
I have model GS563LXSS...all of a sudden the oven
It is not good to do the self clean. The electronics take a beating. Probably the ignitor went out. The oven gets too hot.
Nov 03, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
the operating feature i that it will not let you open untill the oven has either fineshed cleaning or the oven has cooled off
Oct 29, 2009 | KitchenAid KESC307 Electric Kitchen Range
How do I use my self cleaning oven model # FEF357BAWC
just set it to clean then it will lock the oven and let it get really hot it will loosen the spilled food by burning it off and just wiping it off when the oven cools
Oct 29, 2009 | Frigidaire FEF352 Electric Kitchen Range
Should I remove the chrome racks inside before self cleaning?
No you don't have to. They will also clean. Everything will burn off when in cleaning mode. Oven gets really hot, then cools when done.You won't be able to open door until cooled.
Jul 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven takes a long time to heat up
your ignitor could be going out. the ignitor has to get hot enough in order for the gas to turn on and heat your oven. if your ignitor is going out, sometimes it doesn't glow hot enough for the gas to turn on, or it could be that is takes longer than normal to get hot enough to turn the gas on. I would replace the ignitor and that should solve the problem. Joe
Nov 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning electric range
Here are the codes for you range:
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1Safety flip flopReplace Electronic Range Control/Clock (ERC) F2 - E0Shorted keypadReplace Electronic Range Control/Clock (ERC) F3 - E0Oven temperature sensor or oven temperature sensor fuse openedReplace oven temperature sensor or fuseF3 - E1Oven temperature sensor shortedReplace oven temperature sensor F3 - E2Oven too hotReplace oven temperature sensor F3 - E3Clean temp too hot Replace oven temperature sensorF5 - E0
F5 - E1 and E2 Door latch problemCheck door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of yourmodel # 0-5 that will determine which control it takes. Once you havethat # you can look it up at Looks like the part costs about $165.
Oct 08, 2008 | Kenmore Kitchen Ranges
Jenn-Air JGR8855BDS Gas Kitchen Range Logo
215 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
