Frozon at chanel 25 - Televison & Video
    Sergeant:
  • 247 Answers
Go into the setup menu and redo the tuner setup. It will ask you if it is over-the-air (regular) TV or cable and then it will do a scan that searches for channels.
After that it should work.
If not, you will need service.
However, you may be able to get around a bad TV tuner by using another tuner, such as cable tuner or in your VCR to provide the channels. To do this use another input on your TV or select channel 3 on your TV.
Hope this helps :)
Posted on Mar 31, 2008
Ffixing frozon caliper
WD-40 works great for this spray it down real good let set for 30 min. and then you will have to move back and forth once you get it freed up will last
Dec 15, 2012 | 1995 Ford Explorer
Tip
======= http://www.2kuu.com ======= jordan air max oakland raiders...
Issue.... is those equipped with 4.0L engine may experience coolant leaking from the coolant expansion tank. This may be due to cracks that develop in the tank at the radiator mounting bolts locations. The action to be taken is replace the tank.
on Jan 24, 2011 | 1998 Ford Explorer
Tip
There is a known issue with the 2005-2007 Corolla automatic transmission shift logic. The shift points may seem harsh, and the Check Engine light may be illuminated.
There is a technical service bulletin published (TC015-07) that will address and rectify this condition.
The diagnostic code P2716 will be stored in the computer memory. The procedure involves replacing the Engine Control Module (the computer) with an updated unit.
The repair is covered, under the factory warranty, for 96 months, or 80,000 miles, which ever comes first.
I hope that this helps Corolla owners out.
Regards,
Toyota Ed
on Jan 24, 2011 | 2003 Toyota Corolla
My arrow is frozon on screen,for the compaq 61.nothing seems to work thanks
First of all connect the usb mouse then try to uninstall touchpad driver and then install it again.
Oct 07, 2010 | Compaq (153515-001) Touch Pad
I hv PANASONIC COMMERCIAL TV - MODEL CT 2522 HE. I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME...
I am facing problem to preogramme all channels.when I open MANU with univeral remote control,or panasonic master remote,I donot find option for PROGRAMME CHANNEL.SOME OF THE CHANELS SKIP,I want all channels to be programmed..pls give the solution
Nov 24, 2009 | Panasonic CT25G7 25" TV
How to fix style boutique when its keep frozon
go get it fixed when you can and take it to differnt experts
Oct 25, 2009 | Video Game Consoles & Games
Tv is stuck on channel 25
30 YR SERVICE TECH
THER ARE NUMEROUS THINGS THAT MAY HAVE CAUSED YOUR PROBLEM. TAKE IT IN TO A SONY AUTHORIZED SERVICER
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Gps
Try removing the batteries and all cables for 1 to 15 minutes.
Sep 15, 2008 | GPS
I am having difficulty when I try to program the VCR to tape a TV show that I am not watching. When I go through the nine steps that are outlined in the manual on pages 24 and 25 the TV will tape for me...
if you are useing a cabel box you need to split your cable before the cable box with a two set coupler and run the second cable line to the VCR input and this should solve your problem. if you want to record the chanels from your cable box and not watch a diffrent chanel you can leave it hooked as is and select the chanel you want to record with your cable box tunner and leave it turned on, set the vcr to record channel 3 or 4 which ever is the channel you leave your tv tunner on and record that way.
Jul 30, 2008 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
