Ringing noise coming from my philips 30PW9110D/37
I have a 30PW9110D/37 and a couple of months ago it started making a ringing noise. Sometimes as soon as I turn the tv on it will start or if I've been watching tv it will just start to randomly make the ringing noise while watching. But it does eventually stop after a couple of minutes and then starts up again sometimes. Some days are worst then others. I just want to know what is making that noise and can it be fixed b/c it gets really annoying sometimes to listen too.
I also have my xbox 360 hooked up to the HD CVI inputs in the back of the tv, if that is any useful info. to anyone.
Thanks
jsdtrendz
  • 552 Answers
This noise is coming from the power supply.
You may want to look for a local repair shop from this website to get service if desired.
If the power supply were to be replaced, it could be done by you if you are somewhat savvy.
Posted on Mar 31, 2008
3COM NBX V3000 Ghost Ringing
This sounds like you have a phantom user as a member of your incoming hunt group. Meaning you have a user extesion without a phone associated to it (just a mailbox). Check your hunt groups and make sure there aren't any phantom users in them. If so, remove them and this will stop happening.
Jan 28, 2010 | 3Com NBX® V3000 (3C10600BUS)
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
Phillips hdtv model 30pw9110d/37 won't turn on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Apr 28, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Noise under hood sounds like phone ringing
The ringing noise could the heat shield to the spark plugs. As for the other problem, it sounds like it's time for a summer tune up. Spark plug and  wire, air and fuel filter. Good luck and and don't for get the oil change too.
Apr 06, 2009 | 2005 Pontiac Grand Prix
Ringing sound
i would first try to located inside where it's coming from most of the time it's the high voltage fly back needs to be reseated
Jan 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Ringing noise
replace thje diode cause noise , the magnetron are shortening need to replace magnetron /check the old m-=oven same brand and parts and replaceit.
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
27'#27pts5441\37 serial#ya1a0505010585
Model # 27PT5441/37 needs Horiz Driver Kit ( L04.1U chassis)
Part # 483531057673 and replace 47mf/25v capacitor in horiz drive circuit....................................T.
Nov 22, 2007 | Philips Magnavox 27MS343S 27" TV
Ringing Noise
That ringing noise sounds like a deflection yolk or an on board coil is starting to sing as we call it. theres not alot you can do unless you find the source as the deflection yolf in the past we used to stick popcycle sticks into the yolk while in place and hot clue them to get rid of singing yolks.. But its onlty a temp fix. the best way to fix it is too replace the singing yolk. Now if its a coil it could be a loose winding on the coil and hot clueing the coil on the outside sometimes fixes thast too but in the end the best way was to replace the coil that makes noise.
Mar 25, 2006 | Apex Digital AT2008S 20" TV
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
