Question about Toshiba Satellite 2455-S305 Notebook
Toshiba 2455 S305 hinges/Harman Kardon speakers
I have a laptop that my daughter broke the hinges on The machine has Harman Kardon speakers that the hinge pins fit into. I'm trying to find an exploded diagram so I can determine which parts, and the associated parts numbers, so I can order new parts.
  • 2 more comments
  • geowik Apr 18, 2008
    I have tried to disassemble the laptop to look at the problem and cannot even get it apart. I was able to tighten the hinge screws which temporarily fixed the problem but cannot get to the screws very well.
    Help would be appreciated
    Thanks
    geo
  • sailorpink Feb 25, 2009
    The hinge is pulling the speaker covers up and now I have to have a prop to hold the screen up. Can they be pushed back into place or is something broken.
  • rutvig Mar 09, 2009
    I have the same issue. You need to pop open the slightly transluscent panel at the top of the keyboard I believe (this is also how you would replace the keyboard, which i'll be doing in a few days.)
    I've tried looking for replacement hinges online (ebay and elsewhere, which is how i came across this thread) but to no avail.
    hinges for other tosh models are super cheap but apparently, hiunges for the 2455 are super expensive (£50+ each is what my brother has been quoted.)
    I'll post here to let you all know how I get on. it's not looking good however! :(
    This site sells the hinges:
    http://www.notebooksolutions.ca/zc/index...
    It looks like only one (left.) Cannot find the right.
Check out irisvista.com very informational but I am still unsure the hinge part number and if it can be fixed or should it be replaced
Posted on Sep 07, 2008
  • 114 Answers
This looks confusing, I suggest, you should bring the laptops to your local Computer shop.
Posted on Jun 12, 2008
SOURCE:
How do I install intel pro/wireless 2915abg in a toshiba 2455 laptop?
Go to toshiba website. Click on support. Click on download. Choose a category, since this is a laptop. Select laptop and for the family. Select satellite. For the model, type on the model finding filter the 2455-S305 then click go. slect your all operating system and wi-fi. you will see there the available driver for your pc.
Apr 07, 2010 | Toshiba Satellite 2455-S305 Notebook
Tip
I am facing a problem with Media Control Devices, I need to down load the same in my laptop.
Please help.
Nur
on Jul 24, 2008 | Toshiba Satellite 2455-S305 Notebook
Ive got a toshiba 2455-s305 laptop that won't turn on. I've tried it using the power cord, with and without the battery, and when I plug it in it start's flashing in the front, but won't turn on.
Remove battery and disconnect power cord. Press power button for about 5-10 seconds (without battery and power cord) Connect power cord only then turn it on.
Dec 01, 2009 | Toshiba Satellite 2455-S305 Notebook
How to change lcd screen on toshiba satellite 2455-s305? need to change the screen on my toshiba laptop.....looking for step by step instructions on how to remove old screen and can not find anything...
Open the screen as far as it will go naturally. (should lay almost flat with the base) Using flat screwdriver, pry up the hinge cover on the base....there should be two groves to get under it......dont worry you wont break it as long as you dont force it too much, just keep working it till it some off........now you will a set of hinges, prolly with the screws on each hinge.......remove those...........next theres a cable connecting the LCD, you must make sure you remove this one carefully, as not to damage the connectino on the base......on some models, yo must also remove the keyboard by removing the screws associated with it as well.....once again, dont worry, its all cut and dry, and pretty self explanatory once you get those first few pieces and screws off.......once that wire is disconnected you have completely removed your laptops LCD!!!!!! :D GOOD LUCK AND PLS RATE THIS POST!!!!!!
Oct 08, 2009 | Toshiba Satellite 2455-S305 Notebook
Require part numbers for 2455-S305 hinges.
Toshiba Satellite 2455-S305 ...
Left Brake Hinge - P000368300
Right Brake Hinge - P000368310
http://www.impactcomputers.com/p000368300.html
http://www.impactcomputers.com/p000368310.html
Oct 06, 2009 | Toshiba Satellite 2455-S305 Notebook
My toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Mar 19, 2009 | Toshiba Satellite 2455-S305 Notebook
Toshiba satellite 2455 series unable to reboot windows xp/
whats the orig OS installed on your machine? where do you get that recovery cd's ? does it come with the laptop? maybe you've got the wrong OS/ recovery disk with you. Do you have an XP/VISTA installation disk?
Dec 30, 2008 | Toshiba Satellite 2455-S305 Notebook
Toshiba 2455 s305 satellite lid
what are the chances of this? I just threw away my claim form from Toshiba that allows me to claim lost money for replacing this hinge on my laptop! I threw it out because my hinges are perfect, never had a problem. I did write down the website address on that form. Maybe you can try it for your Toshiba. It is www.satelliteremediationprogram.com
good luck!
Nov 19, 2007 | Toshiba Satellite 2455-S305 Notebook
No Sound
It would have to be a new motherboard as the sound will be on board. Obviously you have checked the drivers, but have you run a diagnostic check, you can do this by Start>run> then type 'dxdiag', then press enter. See if windows can locate the problem for you.
Dec 09, 2006 | Toshiba Satellite 2455-S305 Notebook
Toshiba Satellite 2455-S305 Notebook Logo
1,163 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
