Question about Canon DC10 DVD Camcorder
Format error on disc on handy camcorder no disc error message
    Novelist:
    Scholar:
  • 149 Answers
First of all there are a few questions in order to better assist you with this problem. Here are a few:
What form of media are you trying to use with your camcorder?
What "error" is it giving you..besides the no disc error message (aka: distortion in the picture, etc.)?
Has this happened before?
Have you tried to re-install the media and make sure that you didnt insert it incorrectly or that the media was ok and no film was ruined?
How long have you owned this?
Thank you for your time. I will keep an eye out for your next response back in order to better help you find a solution.
Posted on Mar 31, 2008
  • Anonymous Mar 31, 2008
    Oh yeah, and have you tried another form of media to see if its still doing the same thing?
    Is it PAL or NTSC that you own?
    Scholar:
  • 58 Answers
This happens alot with the Sony handycams ... try reading the disc in another DVD then see if you can rescue the recording ... There donst seem to be any other route you can take to correct this ...
SOURCE:
Disk error
Sony handy cam dcr-sr20 HDD format ERR 31:00
Apr 30, 2013 | Sony Handycam DCR-DVD201 DVD Camcorder
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
My camcorder states Movie recording disabled. It is a sony handy cam dvd108. I am using brand new sony mini-dvds. I have tried so far the following things: cleaning the lens, cleaning the pick up lens,...
Hi! Looks like that the camera has a system crash. I strongly suggest that you have it looked at by a qualified technician to check the circuit board of the camera. Hope this helps and thank you for using FixYa!
Oct 17, 2010 | Cameras
I get a message on the screen that says, "recording disabled." How do I fix this? I have a Sony Handycam DVD/RW Wide LCD
This message appears when mini dvd disc got some error in recording tracks, if its rewritable mini disc then format it as option is available in camera settings menu and if disc is once writable then use another disc as it can not be formatted.
Caution: Format will erase/ delete all files on dvd disc and refresh the dvd disc.
Jul 25, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Format error when i finalise the disk
If a FORMAT ERROR message is displayed, then the inserted disc is not formatted or it is recorded in a different format not useable by the camcorder. If using a DVD-RW or DVD+RW, format the disc prior to use. Otherwise, use a different disc.
Mar 21, 2010 | Sony Handycam DCR-DVD201 DVD Camcorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
6 seconds into recording the following message appears: write error - to recover disc, presss OK. having pressed 'OK' the screen then shows 'Disc Loading' message - this takes time and uses up battery...
It turned out to be a simple case of a defective disc, which, for some reason failed to work satisfactorily. I replaced it with a fresh disc (JVC 30 min DVD-RW) from he same batch and it formatted ok and worked well too. I checked that it had recorded and I was pleased to say that it had. So let's hope that that was the cause of my problem, because the camcorder is now just out of warranty.
Many thanks for your halp in this matter.
Regards.
Jim Stringer
Oct 13, 2009 | Samsung VP-DC161 DVD Camcorder
C 13:02 dvd-rw mini disc errors
It's not recommended to format a disc in the Computer and use it in the Camcorder.
It seems that there is an issue with the disc.
The disc should be formatted within the Camcorder itself.
I will forward a link to a page where you can get the information regarding the error message appearing on the LCD screen of the Camcorder.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C79466
May 15, 2009 | Sony Cameras
I found a program called "inDisc Recovery" that located the lost VOB file, and saved it to my computer. You put the dvd-r in your computer drive, run the program and then look under "deleted" folder
Dec 27, 2007 | Sony Handycam DCR-DVD403 DVD Camcorder
Canon DC10 DVD Camcorder Logo
105 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
