Question about Dell E173FP 17" LCD Monitor
Dell E178FPf LCD monitor goes to standby and won`t come on again
My DELL E176FPf LCD monitor goes to standby and will not fire up again unless i remove it from the main electric and reconnect it works perfectly when it is on .
If i leave it for about ten minutes with no activity it will go to standby and although the screen is black the back light appears to be on.
Any help you can give me will be greatly appreciated as I am a pensioner and money is tight.
Many thanks Robert
  • penpal2 Apr 01, 2008
    Penpal2 says many thanks to Buschchris1 and to Fixya, the former for sorting my problem and the latter for posting it.
    I have had months of tearing my hair out and Buschchrist1 guided me to sorting it in about 90 seconds BRILLIANT.
    Master:
  • 474 Answers
Check your Power options in Windows.
right click on the desktop. select properties, Gop to the screen saver tab, click on the power button at the bottom right and check to see if its set to turn off or standby the monitor, turn this off.
Keep the screen saver on and set it for like ten minutes.
Also, on the monitor itself, it may have a sleep or power save option set as the default. check all the monitor settings on the actual moniotr itself.
Posted on Mar 31, 2008
  • Chris Busch
    Chris Busch Apr 01, 2008
    Always glad to help.
  • Abed Elrahman Roudieny
    Abed Elrahman Roudieny Mar 23, 2013
    Thank you chris this is working with me
Dell monitor power on and power light goes on and off
First place to look will be the power supply caps, look for caps with bulging top, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
http://www.lcdrepair.us/e176-177fpc-inverter-power.html
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
http://www.lcdrepair.us/e176-177fpm-inverter-power.html
Feb 16, 2010 | Dell E176FP 17" LCD Monitor
Dell E152FP monitor after startup or coming back from standby the screen will show up and 5 seconds later it disappears. I turn off the monitor and turn it back on. The image comes back again but it...
Hello
Probably the monitor. LCD monitors use electrolytic capactors which change value with heat. The power board in yours probably has 6 to 8 caps whic need replacement. Take it to a reputable repair person or check out my websit.
Thanks
Jan 07, 2010 | Dell E153FP 15" LCD Monitor
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
Monitor stuck in standby
Try tapping F8 when booting and then choose 'safe mode with networking'
if this works go to the lcd manufactures web site and look for a specific driver for your screen.
Aug 30, 2009 | Dell E551 15" CRT Monitor
My monitor screen goes black
The monitor is going bad. Either going to be a bad screen or a bad inverter. Also Since you tried it on another computer and its still giving you the same symptoms, you know the computers are fine. To be sure, try another monitor on your computer and if you get video on the new monitor then thats another way of verifying that the dell monitor is bad.
May 16, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Acer x223w issues- freezes
I think it could be an issue with resolution. Since the monitor is so big, some video cards, I noticed, can't support the high resolutions that the monitor can, if that doesn't work try 16-bit instead of 32-bit.
Feb 25, 2009 | Acer 22" X223w LCD Monitor
Monitor in Power Save Mode
The inverter power logic is probably going bad. You can get it here as well as look at instructional videos on DELL monitors.
May 04, 2008 | Dell E176FP 17" LCD Monitor
Monitor won't turn on
The inverter power supply logic board has probably goe out. You can get it here or have it fixed.
Mar 30, 2008 | Dell E176FP 17" LCD Monitor
Dead, Dell E176FPf
If it is still inside the three year monitor warranty period I would recommend calling tech support to have it replaced. Larry Dell Customer Advocate
Apr 16, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
461 people viewed this question
Alun Cox
