Question about Motorola TalkAbout T5530 2-Way Radio
Will a Motorola TalkAbout T5320 transmit to a Motorola TalkAbout T5530?
My Talkabout T5530 will transmit to my T5320 , but my T5320 can't be heard on the T5330, on any channel. The 5320 works well between my other 5320, and they can be heard on the 5530, but the 5530 can't be heard on the 5320's. Ideas?
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a “Privacy Code” or “Quiet Code.” The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on your T5530s but is not enabled on your T5320. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code “4” on the Motorola TalkAbout series actually corresponds to code “A” on the Motorola Sport models.
Posted on Aug 24, 2008
    Sergeant:
  • 250 Answers
Hello Blindmaster,
Best Regards,
Agent Ken
Go Ahead. Use Us.
Posted on Apr 07, 2008
6ya staff
SOURCE:
How do I unlock a Motorola talkabout
Press and hold the Menu button (the center section with the + and - buttons to the sides) until you hear a beep (3 seconds or so). After that, when you press and release the Menu button, the Channel number should flash indicating that you can change the channel. In the future, you can toggle the keypad lock by pressing and holding the Menu button.
You can find more information on the Keypad Lock feature in the manual. See page 14 and page 21. The manual is available from ManualsLib: https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html . For the diagram of the Motorola Talkabout T5320, see https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html?page=14#manual . The Keypad Lock is described here: https://www.manualslib.com/manual/106993/Motorola-Talkabout-T5320.html?page=21#manual .
I hope this helps. I usually use my Motorola Talkabout radios with the keypad lock active. I hit the various button accidentally when working in the field.
Aug 28, 2018 | Motorola Radio Communications
Constant static on talkabout t5320
Could be a sign of a bad battery. Static is a good indicator of a rechargeable battery nearing end of life.
Jan 18, 2014 | Motorola Talkabout T5320 (14 Channels)...
Stop the sound of a Tone when Keying to Transmit..
That generally means that it's set to transmit on an invalid frequency.
Jul 26, 2013 | Motorola TalkAbout T5530 2-Way Radio
Where and how can i get a charging station for a Motorola Talkabout T5530 Walkie Talkie?
Hi Ken,
Take your radio in to your nearest Radioshack or similar store, and they'll help you to get the Charging dock for your radio.
I hope this helps.
Cheers,
Peter
Aug 07, 2012 | Motorola TalkAbout T5530 2-Way Radio
I have the Motorola T5530 Talkabout and I have charged them and I cant get them to work. Can I get a manual somewhere as I have lost mine. Tks
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
You might start by checking the frequency, code and Qt filter (if any), to be certain they are set alike.
Best regards.
Sep 05, 2011 | Motorola TalkAbout T5530 2-Way Radio
I lost one of the hand sets - is it pssible to
The TalkAbout line of radios operate on the same 14 FRS/GMRS frequencies. If you purchase another model TalkAbout they can talk with one another. Here is a link to the Motorola TalkAbout Store http://www.store.motorola.com/mot/en/US/adirect/motorola?cmd=catDisplayStyle&catKey=601700
Best regards.
Apr 09, 2010 | Motorola TalkAbout T5530 2-Way Radio
Talkabout Motorola T5530
I found the T5000 manual here (It covers the T5000, T5500, T5530 and T5550)
http://www.giantintl.com/RadioPDFs/manuals/T5000.pdf
Semper Fi,
Jstwhln
Jun 24, 2008 | Motorola TalkAbout T5530 2-Way Radio
Motorola TalkAbout T5530 2-Way Radio Logo
823 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
