Question about Philips DVD783CH Multi-disc DVD Player
Philips dvd783c wont spin.
The disc loads into the tray
tray closes
spindle makes a squealing nose
few seconds later
i get a "disc error" display.
i know these discs work because they work in every other dvd player.
any suggestions?
  • rai_exe
    rai_exe Mar 31, 2008
    well the tray is blocking the way
    i took the cover off and everything works out good, i can hear the lens trying to scan it but the spindle wont turn to let the lens read the disc
    it just makes a high pitched squealing sound
  • rai_exe
    rai_exe Apr 02, 2008
    its fairly new too, the player worked perfect up until recently.
    my brother pushed the tray in because it froze and i had to realign the gears.
    it was fine after that but it stopped spinning.
    thanks for the info, i hope i get it worked out.
    Novelist:
    Scholar:
  • 149 Answers
It sounds like one of the hindge/wheels are off set. Most of the time that can also cause the lazer lense not to come up all the way in order to properly read the disc. When you keep the door open and press start does it allow the lazer lense to come up all the way? That is the small circle glass peice you will see when you look in--some you can see it some you cant.
Let me know.
Thanks.
Posted on Mar 31, 2008
  • Cambryn Reichert
    Cambryn Reichert Apr 01, 2008
    Yeah I had the same issue with one of my DVD players as well. The thing is that I had to pick it up in order for it to work properly..for a while. Otherwise this is something a repair store can fix for your and not something I'd recommend doing unless you have worked or fixed some electronics before. They normally can fix it simply or it might be a bit more elaborate. Some places will take a look at it for free and then you can determine if you want it worked on or not..so an estimate. But otherwise there isn't any other simple fix for this at it needs everything opened in order to operate on the insides.
I have a Philips HTS5550 home theater and i have found out that the dvd spindle spins a disc for a few seconds, then it stops and displays a "No disc error" on the screen. What is the solution to repa
First, make sure you're not trying to play a bad disc by testing with another factory-burned DVD. And ... please do not be insulted here ... be sure the labeled side is facing upward. If still the same, the laser is mot likely defective and you will not be able to repair that yourself.
Aug 07, 2014 | Philips HTS5550/12 DVD/DivX Home Cinema...
Tip
DVD PLAYER REPAIR (NO DISC ERROR)
Before you attempt to repair your DVD Player yourself, make sure that you have necessary tools and test instruments like philips screw drivers, multimeter, soldering iron, soldering lead, soldering pump, etc...
This is a DVD/MIDI Player with a "no disc error" upon loading any disc that played before...
Watch this VIDEO
First I've loaded it with disc and observe the movement of the optical lens and the spindle motor. First thing I've noticed that the spindle motor didn't oscillate upon spinning and it's spin slowly unlike the normal RPM...
I've suspected the spindle motor was already bad but still to be confirm...
Unscrew the disc holder plate from the assembly to keep away the magnet touching the spindle motor, this may affect the reading and spinning of the motor upon testing with the multimeter.
This is how it looks like after removing the disc plate holder in the assembly. Spindle motor is secured with 2 small screws in the lens assembly.
Pull-out the connectors from the main board to see the underside of the tray.
You may test the spindle motor with your multimeter set in resistance measurement (ohms X1) even connected to the small board.
Bad motor will read either less than 5ohms(shorted winding) or infinity (open winding) and will not spin.
Good motor will read more than 50 ohms(depends the size) and will spin upon testing. Watch this VIDEO.
Onced you've confirmed that the motor was already faulty, unscrew it from the lens assembly.
Replaced the spindle motor with new one. Before you install the new motor make sure that the clearance of the disc holder is the same as the old one. Compare first the clearance because if it is to high the optical lens will not read the disc same if it is to low....
After replacing the motor re-insert all the connectors to the main board.
I've load same disc which does not read a while ago and observe what will happen. Observe the disc and the sound oscillation from the spindle motor in this VIDEO.
Hope that the above information, pictures, and video will help you fixing your DVD player yourself.
Thanks for visiting Fixya.
Have a nice day!
Jdvillanueva
on Apr 18, 2011 | Bose 3 2 1 GSX System
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Cd will not eject. Keeps giving message "Now OPC" but will not do anything and will not eject cd either.
To remove a stuck CD from Tascam CC222 MKII
This solved the "Now OPC" problem
1. Unplug unit
2. Remove the top cover, (3 screws on each side and 3 on the back, lift cover).
3. Plug in unit.
4. Power on the unit to observe the drive spindle spinning clockwise, (1" disc on top of drive).
5. Turn off unit, do not unplug at this time.
6. Use a small screwdriver to prevent the drive spindle from spinning.
7. Power on the unit preventing the spin.
8. In approximately 10 seconds the display will read "Disc Error" and the CD tray will open.
9. Remove the screwdriver and the disc.
10. Turn off the unit and unplug.
11. Replace the cover.
12. Use a better quality disc.
Sep 23, 2010 | Tascam CC-222mkIII CD Player / Recorder
Error code HO2 appears after inserting dvd panosonic NV-VP30EB
To my knowledge, most H02 errors on a Panasonic DVD player would indicate a spindle error, that is the central motor that spins the disc. Normally, this would require an in-shop repair as electronics is involved, however, you could still try:
  • close the tray with no disc inside;
  • press on the back skip, pause, and play buttons simultaneously and hold for about 4 seconds;
  • when the screen blanks and then "initializing" appears, release the buttons.
Alternately, you can try:
  • remove the top cover;
  • clean the spindle motor with compressed air;
  • manually turn the spindle counter clockwise and then clockwise numerous times to exercise the motor;
  • power on the player, insert a disc and manually assist the disc to start turning.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 20, 2008 | Televison & Video
DVD not spinning
HI nIKITA2471.
If its a faulty drive try this.
Step Remove the top of the unit, using the appropriate-sized Philips screwdriver. Consult the manufacturer's warranty details to determine if this will void it.
Step Apply power to the unit, and eject the tray. Lay two paper towels over the internals of the unit, with the paper resting on the sides of the chassis. Power will remain on during this procedure.
Step Spray three short bursts of WD-40 (or similar lubricant) under the plastic disc that grabs the DVD and pulls it into the motor and drive shaft (it will be a quarter-sized black or gray disc that is attached to the spindle motor). Let settle for a few seconds.
Step Place a commercial DVD into the tray, and allow it to spin up. If it does not, your player may require professional service.
Step Gently clean up excess lubricant sling (throw off that occurs when the motor spins up) with paper towels and cotton swabs, paying special attention to the laser assembly.
Step Re-attach the top of the unit.
do not let any spray get on to the little lens that reads the disc.
or you could try just buying a lens cleaning disc and see if that works first.
Nov 30, 2017 | LG GSA-5163D DVD±RW Dual Layer Burner
Xbox 360
Bad Cdrom/dvd
The laser going bad is a pretty common issue with the drives, since it's a Hitachi that spindle motor could be all gunked up with dirt as well and cause that issue also.
if ya have a Hitachi, if it's a Samsung it could just be the laser.
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Oct 03, 2007 | Microsoft Xbox Console
Disc loading problem
disk draw timing is probably out ( gear or mechanism jumped out of time
Jan 23, 2007 | Cyberhome DVR 1600 DVD Recorder
Philips DVD783CH Multi-disc DVD Player Logo
134 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
