New VCR won't work but DVD will.
Can't get VCR to operate. DVD will run but not VCR
Found out that you need a turner to make the VCR operate. So we took the DVD and VCR back to Walmart. Thanks
Posted on Apr 01, 2008
Remote stopped functioning for dvd\vcr unit
When the remote control won't operate the DVD player recorder, check the batteries. Try replacing them and see if the remote works. If the batteries are fine, the code on the remote and the code on the DVD player recorder might not be the same. When aiming the remote at the unit a number will be displayed. To set the remote to the same number, which will be 1, 2, or 3, press down OK on the remote as the appropriate number at same time.
God bless you
Sep 27, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
Vcr won't record
first try a new set of connecting wires these are the usually cheap wires that will give out easily. if that don't work ,its most likly gonna be the tape recorder itself. how old is it.
Jan 21, 2012 | GoVideo DV1130 DVD Player/VCR
Dvd tray won't open
The tray needs a new motor with a new pulley that does not slip on its shaft and get a new belt too.
It is easy to pull the dvd tray unit out of a GO VIDEO DVD+VCR machine to replace the motor with new pulley on it and the belt should be renewed too.The motor NOW may run only to push out the tray but it will not pull it in to LOAD the DVD or CD.
This is what I found after troble-shooting the function.
From Jim, and I need the same things. Can anyone tell me where I might buy those idems?
Oct 07, 2011 | GoVideo Go Video DVD/VCR Combo
My dvd won't play. every dvd i put in, it says bad disc. the vcr works fine. is it time for a new system. i tried a head cleaner and it says bad disc
Not necessarily time for a new one. I would give the DVD player a good cleaning before you consider a new unit. A good cleaning disk with some little bristles on it. Run it through three full times. DVD players are far more sensitive than VCRs and have to be cleaned even two weeks or so. When they get real dirty it can take some fooling with to get the DVD player to even accept the cleaning disk. But if it just won't accept the cleaning disk and you can't watch a DVD in it then it's time for a new one. I had a DVD player one time that took an hour of fooling around with before it got cleaned good enough to play DVDs. Worked for a couple years afterward.
Regards, Tony
Apr 19, 2011 | GoVideo Go Video DVD/VCR Combo
The vcr stopped working, tape goes in but won 't work. the dvd stills works.
most likely a mechanical issue , look inside for anything laying inside the VCR section.
a piece of a label or a toy etc. if all looks well it could be a bad sensor , bad (dirty)mode switch
or sinply a jammed gear or arm.
a good way to check the VCR section is to turn the loading motor and see that it moves correctly
hope this helps
Dec 17, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
We have a new vcr snowy
It seems that you need to take the new unit back for exchange, since you are using the same output for the vcr and the dvd and your dvd is giving you a good picture, the vcr is acting up and since it's new either exchange or repair will be needed.
Sep 01, 2009 | Philips Magnavox TS3260C 32" TV
Broksonic VCR
It should be either ch 3 or 4, BUT the VCR must be turned on and in the "vcr" mode. There may also be an way that you can switch between tuner and Video on the VCR, it would need to be in video mode.
Hope that helps...
Mar 26, 2008 | Televison & Video
Universal remote code for Symphonic DVD/VCR combo
I believe if you press rec twice you can record. Thats all I have found so far
Mar 25, 2008 | Symphonic WV806 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
