Question about Onkyo TX-SR502 Receiver
Protection mode I have just recently got a onkyo TX- SR502 and it is in protection mode. My question is, is there any way to diable the protection mode other than taking it to a repair shop?
  • Rickyracer Apr 27, 2008
    I have a TX-SV919 with a similar problem...but I think it was caused by someone plugging an oscillating fan into the back of the unit. It drew too many amps I guess. Where could I get a transistor and a couple of resistors for it?
I banged my head against the wall on this same issue and finally realized that my rear surround speakers were mixed. My rear right was wired to rear left because I was turning around to see L and R. It would shut off at about volume level 40, which was loud but not rumbling. It now ROCKS and is in no way a problem with heat. I have always run it with the cabinet open to allow air to circulate.
Posted on May 30, 2008
  • 88 Answers
You have to verify your connection cause if you are a short circuit in your different output or input the protection mode is on. it's an internal security
first disconnect all your output speakers, and restart your amplifier if the protection mode is on again try to disconnect all your input device and restart your amplifier, the protection mode should be off, so after connect one device after one to check who makes your protection mode on
Posted on Mar 31, 2008
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
When connecting optical inputs there is no audio output
You have to assign each digital input.
Register and download the manual for free at
Search the document for "assign".
Mar 27, 2011 | Onkyo TX-SR502 Receiver
My TX-SR502 AV receiver has no output sound in any mode but CD. Thsi has been a progressivly deterioration from sometimes sound to finally no sound.
sounds like the receiver input mode may be in the wrong setting. or check the 'direct' button. turn it off
Nov 03, 2009 | Onkyo TX-SR502 Receiver
No sound coming out of speakers something is wrong with the receiver
check if it goes to protection mode on power on. see to it that speaker selector switch is set.
Is your speakers connected properly?
Is your music source ok?
Do you hear a click after you switch on the power? the click indicates that the time-on delay transfers the amps output to the speakers which prevents thumps going out to the speakers.
Once it goes to protection mode you need to have it serviced. This is due to a fault in one of the amps and that it protect the speakers from further damage.
Aug 17, 2009 | Onkyo TX-SR502 Receiver
Onkyo TX-SR502 protection mode
Hello! One of the channels in your unit has shorted output transistors and is sending about 60 volts towards your speakers. If your unit has an output chip ( I don't ever remember seeing an Onkyo with a chip though...all discrete transistors ) it is shorted. Your unit is well worth repair. Onkyo is an execellent unit. Please rate this solution! Thankyou!
Oct 08, 2008 | Onkyo Audio Players & Recorders
Onkyo receiver question
One of the speaker maybe are in bad conditions and that burn out the audio amplifier IC you need to change it or send the device to a repair center.Good luck
Apr 28, 2008 | Onkyo TX-SR502 Receiver
Amp Protection Mode
from LANCE P: I fixed it. Be sure that all your speaker connections are perfect. No element frays that can arc, no +/- problems, no single barely connected wire. My problem was volume sensitve and I evidently had one + wire that was loose in the back. I corrected it and ran it all day with surround and good volume with no problems. So diligently check ALL YOUR SPEAKER CONNECTIONS, both in the back of the unit and at your speakers
Feb 27, 2007 | Onkyo TX-SR502 Receiver
Onkyo TX-SR502 - o Sound!
pls make it reset at factory level ,but pls note that you have to keep it in aauto mode
Mar 12, 2007 | Onkyo TX-SR502 Receiver
Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Dec 31, 2006 | Onkyo TX-V940 Receiver
Onkyo TX-SR502 Receiver Logo
1,155 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
