can anyone walk me through setting up dhcp on this thing. i went into the system settings and hit dhcp and it said "programming" and then after that working i rebooted the printer in hopes it would pick up an ip but it did not. it instead is showing a 11.22.33.44 ip address... it should be a 10.18.90.X address. any help is much apreciated, thanks
Ok, you do not want DCHP to be on. Select IP address and enter the IP back in. Press ok, and ok, until it says "programmed"
Hopefully, you did not wipe out the subnet address, and gateway address. It would be easier to print a config page out to see. If you did, get to a command prompt on your computer, and type:
ipconfig /all --> then enter. That will give you the subnet and gateway if you lost it. If you have any problems, email me.
Was this solution helpful? Show your Appreciation by rating it:
