I neen a driver
I need the driver for PNY Optima Pro Attache 8 GB. It is for a pc that has no internet access. Where can I find it and can I download it on to a disk to transfer it to the old computer that I can not connect to the internet?
  • Anonymous Mar 15, 2009
    rtg
  • 156 Answers
Hmmm.. I am not sure where to find the drivers, or if the driver is a must. But if you have a driver file, then you can take it to any system and install it there.. Intenet connection is not at all required.
Posted on Apr 12, 2008
SOURCE:
How to remove 'write protected' from PNY Optima Pro Attache 2 GB USB 2.0 Flash. My flash drive named above, always tells me that the drive is write ptotected whenever I want to add or remove a...
If it doesn't have a sliding "write protect" switch on it as shown in step 2, try step 5 or step 6 on this page:
http://www.makeuseof.com/tag/how-to-fix-write-protection-errors-on-a-usb-stick/
Small sd cards have a small slider in the case itself. Flash drives may have partitions on the drive itself. One or two of these small partitions may have write protection on them that cannot be removed. If you have too much trouble, put the flash drive in a usb slot, wait for it to be recognized. Open the control panel and open administrative tools. Click on computer management and then in the left lower pane, click disc management. In the right pane, there will be a window that shows and lists all the drives and partitions. Look for your flash drive and you can delete volumes, partition the drive etc.
remove write protected from PNY Optima Pro Attache 2 GB USB 2 0 Flash...
Mar 05, 2018 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
How to get a driverfor pny 8 gb flas drive for
Then you will have to use a diskette or a CD, download the driver on some other computer, unpack and copy it to the diskette or burn on a CD-R.
Go to this link to download the drivers and for further reading on Windows 98 USB storage issues.
Dec 29, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Pny attache optima pro 8g usb drive disk space problem
Yes, and Perfectly too.
What you should do is,
depending on your operating system,
Right-Click on 'My Computer Icon', then select 'Manage'.
When you get to Computer Management page,
Click on Disk Management on left hand side,
This will display ALL the disks installed on your system, either partitioned or not partitioned, formatted or not formatted.
Then go to the ones that are hidden, not created, or not displayed, right-click on it, then you'll see different actions that you can perform.
Also, in some instances, what you just need to do when you get to this page is to assign a new, distinct, drive letter apart from the ones already in use on the system.
This will automatically bring out the hidden drives.
Hope I have helped you out.
Goodluck
Oct 29, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I HAVE A PNY OPTIMA PRO ATTACHE 2 G AND IT WONT WORK IN MY COMPUT
then download the software, this device can run with his own program...
Jun 17, 2009 | PNY Technologies GeForce 6200 128MB AGP...
My flash drive says I am using data when I am not
i mean when i insert my flash disk in to the computer and then try to open it displays format disk
May 01, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
2g attache optima pro black/amber went to write protected...how do I fix it?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Dec 10, 2008 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Drivers
Go to ADD HARDWARE and try to force the install.
Just so you know, Optima Pro Attaché USB 2.0 Flash Drive was designed with Windows Vista in mind, and works in conjunction with new SuperFetch (intelligent caching) to enhance system performance for quicker startup and windows multi-tasking.
But it's also compatible with most PC/MAC laptop and desktop computers with available USB 2.0 port (Backwards compatible to USB 1.0).
Jun 30, 2008 | Computers & Internet
Optima attache
You may need to uninstall your USB port drivers thru the Windows Device Manager and reboot . Windows will see your USB ports when it restarts and reinstall the drivers which will include support for flash drives including Pny flash drives.
Jun 20, 2008 | PNY Technologies GeForce 6200 128MB AGP...
Windows Vista Home Premium will not let me open PNY Optima Pro Attache 4GB
the files from XP may or may not be readable on vista...and I can assure you vista files will not read on xp..
recommend you get two of those.
no guarantees of interchangeability from xp to vista(why am I not surprised?)
check your computers' warranty here for FREE
Mar 02, 2008 | Computers & Internet
Computers & Internet Logo
252 people viewed this question
Ekse
Alun Cox
