Beta vcr tht may be magnatized
It put out video befor. now it wont. it has been setting up a long time.
no video or audio. it has been cleaned but still wont work and i feel
it needs to be demagnatized.i cant find a demagnatizer. can you
help me find one???
R A POPE
  • 180 Answers
Try to clean the video head carefully.if the problem still exist replace the video head.if there is no video,audio also will be muted.demagnatizing will not solve the problem.
Posted on Apr 04, 2008
How do i hook up my new cable box for descrambling to my vcr
If the cable box has audio and video outputs on it then use RCA type cables to connect the outputs of the cable box into the video and audio IN of the back of the VCR. Then select L1 on the VCR. If your TV has video and audio input connectors connect another set of cables form the VCR OUT to the IN puts of the TV, then select the AV inputs on the TV. If your TV doesn't have video and audio inputs, then use a coax cable from the RF/Antenna OUT of the VCR and connect it to the antenna jack on the TV. Now select 3or4 on the VCR to whatever works for your location and tune the TV to that same channel. That's it ...you now can watch and record the channel you're watching. You will have to have the VCR powered up all the time to watch TV
Jul 28, 2017 | Symphonic SL260A S-VHS VCR
Buzz during playback, but only on SOME tapes!! When i adjust tracking manually, pictures quality suffers.
Bad recording VHS or old VHS tapes,will sometimes causes this problems,because of degrading magnatic tapes.Sorry this problems,u did the fixed adjusting manual tracking,that it not fixing the problems,sorry that all u will getting that kind of quality of picture.
Mar 21, 2011 | GoVideo Go Video DVD/VCR Combo
My VCR won't play my movies! The tapes are fine its just when I put the tape in it just shows a scraggly screen. Everything is plugged in but my movies won't play. What do I do?
If the vcr is running the tape, your video head is probably dirty, try using a cleaning tape if you have one. The second option is use a brand new blank tape T120 and set the the machine to sp speed (2hr running time) and let the tape run the full course. The third option is to remove the lid of the vcr and carefully clean the video head with a swab dipped in rubbing alcohol rotating the head by hand as you proceed allowing several minutes to dry before loading your tape.
Dec 21, 2010 | Sharp VC-H810U VHS VCR
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
Video heads of Sanyo VWM-800 4 head vcr need cleaning.
Take the top off and spray the main head with Servisol Video 40. (image below) Also the tracking and audio heads.
Wait for it to dry before putting a tape in. In the future use only this it is much better and cheaper than cleaning tapes.
Mar 10, 2010 | Sanyo VWM-800 VHS VCR
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
Beta VCR
Get all the belts changed in it and the pinch roller replaced. All of those decks had real rubber belts plus the lubricants where made from animal fat. It's a wonder it does anything at all but beta is great its the foundation of HDcam and the SR series today and what a beautiful picture.
Dec 11, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
