Question about Dell OptiPlex GX620 PC Desktop
Unsuccessful memory upgrade
I've got this small form factor Dell Optiplex GX620 and I wanted to upgrade the memory from a pair of 512 MB simms to a single 2GB dimm. The existing memory was 533 MHz (PC 4200) so I figured I could just buy anything faster than that and under-clock it.
I ended up buying a 2GB strip of 800 MHz (PC 6400) memory for $30, and installed it. The system appeared to boot just fine, but when I try to log into windows, the system hangs for a moment, and then gives me a series of errors before starting a shutdown timer and rebooting.
Does anyone know if this is related to the memory speed being too fast, just some configuration problem, or something else?
Thanks.
-Doug
Memory must be installed in pairs.
Posted on Dec 19, 2008
    Master:
  • 474 Answers
I work on GX 620 dells alot. I work on them for a school district.
They have alot of issues. Particularly with memory issues, try reseating the memory or trying a different memory slot. You shouldnt have to under clock it. Just run it as normal.
If it beeps on start up, then its probably a memory problem. The dell website has online support and will give you a list of dell beep codes
http://www.support.dell.com/
you can type in your dell service tag number located on the back, or just picking out the model.
Try using just using the new memory stick by itself without the old ones.
If your computer came with a disk ( it should) It either Blue or Black, if its black, boot from cd and it will load a test program, try using that to check that the memory is good. If its blue then its older and just lets you re-install windows.
If its looping, where it gives you a black screen with options to boot in safe mode but restarts no matter what option you pick.
Load the windows cd like your going to re-install, Boot from cd ( F12 ) on boot, pick boot cd drive and when it loads, pick ( R) for repair and when it goes to command prompt, type in. ( chkdsk C: /p ) exactly like that
it will run a repair. When done, type EXIT and hit enter.
When it restarts, remove the disk and see if it gives you the option again to pick how to start windows.
Pick ( star windows normally ) see if this works.
If the repair works then it wasnt the memory as much as it was just Dells Crappy hardware configuration.
Let me know what happens and i can try to help you further.
It could be a bad memory stick that you happened to get.
Good luck.
Posted on Mar 31, 2008
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
How can I upgrade the memory of dell gx150 optiplex to 1 gb
Sorry - but you CANNOT upgrade the OptiPlex gx150 to 1 GB RAM - the maximum memory that system will recognize is 512 Mb.
Apr 26, 2014 | Dell Computers & Internet
I want to know if i can install a siig firewire PCIe card into a dell optiplex 620 all-n-one computer
Hi Carl,
I am guessing you are asking about the Dell Optiplex "GX"620. :-) Anyway, if you are using the all-in-one setup shown in this picture:
then unfortunately, with the small form factor case that is used with this particular version of the Optiplex GX620, the motherboard doesn't have any expansion ports to be able to install a PCIe card. Here is a picture of the small form factor case with the side panel off of it so you can see how little room is left in the case after all of the components are installed.
As I am not familiar with what you are trying to accomplish or why you need a firewire card installed, I can only make a small suggestion, such as looking for a firewire to USB adapter for whatever you are trying to connect to your computer. If you are able to expand on what you are trying to accomplish, or what kinds of problems you are having, I would happy to try to lend you my expertise. :-) I hope this helps.
-Nathan
Sep 26, 2013 | Dell Computers & Internet
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
What is the most memory l can put in my dell optiplex gx 280 desktop ,l have 512 in it now
For mini-tower and Desktop
You should have 4 slots.
4GB is the max if you replace all the sticks.
For gx280 SFF (Small Form Factor)
You should have 2 slots.
2GB is the max if you replace all the sticks.
Nov 17, 2010 | Famous Brand Dell Optiplex GX280 Intel...
Increase the amount of shared video dell gx280
Hello!
Don´t lose time for that, I think that you have integrated grafik in own chip, and they have same options with 1 or 64 MB, option in bios, that isn´t a standard shared grafik. Try AGP card if you have a socet for that.
Oct 30, 2009 | Dell OptiPlex GX280 PC Desktop
How do I remove the exterior plastic panels on a Dell GX620 case? I want to replace a couple of scuffed panels with ones from another case.
Let's begin by providing a link to the User Manual. This page has a link to view it on-line or download it. Your choice.
GX620 Manuals
Now for the cover. You don't say what form factor you have. (There are 4.)
If you go to this page and go to the bottom, there are 4 links corresponding to each of the form factors that give instructions for removing the cover.
GX620 Before You Begin
Also keep in mind that your computer has a Chassis intrusion switch. Once you remove the covers you will need to reset it. Instructions are at the bottom of this page:
GX620 Chassis Intrusion
That should get you going. If you use the on-line manual, just bookmark it for future use.
Thanks for using Fixya.
Oct 16, 2009 | Dell OptiPlex GX620 PC Desktop
My problem that i can uprade my SDRAM 128 to 512
You can use PC-100 memory up to 512MB max (2X256MB)
Apr 12, 2009 | Dell Optiplex GX110 (2909T) Motherboard
OptiPlex GX270 mini tower
Remove the 256mb memory and insert the 512mb memory in slot1 and see whether it works. Please note that the memory needs to be in pairs.
I think the GX260 is mini tower has two different moles
1) PC3200 compatible with memory - 184 Pin DDR3200 400MHz
2) PC2700 compatible with memory -184 Pin DDR2700 333MHz
Please enter the service tag on dell.com and find the manual and the right memory for your PC
All the best!
Dec 17, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Memory
Hi
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Mike
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX620 PC Desktop Logo
204 people viewed this question
Alun Cox
