Question about Aiwa LCX-330 Shelf System
Speaker Problem ONe of the speakers isn't working. It produces only minimal sound, even at the highest volume. I tried switching the speakers and the other one works fine, so it's not the connection that's bad. Before I replace the whole system, is there a way to buy just one replacement speaker that will work with this system? I don't remember how much I paid for the system, so maybe it's better to just replace the whole thing? I'd appreciate your advice. Thanks, Carol B.
  • Carol B Apr 02, 2008
    Dan -
    Thanks for the suggestion. I had already tried switching the speakers and determined it's the speaker - not the unit - that's bad.
    I don't solder so I picked up a cheap speaker and will see if/how that works. Otherwise, the player is not worth all that much so I will probably just replace at some point.
    Thanks again.
    Carol
The high speakers in my car will not work how do i fix this
Posted on Feb 16, 2009
  • 4,234 Answers
Before you replace the speaker, swap the left and right. If the sound problem follows the speaker, the speaker is bad. If the problem remains on the same side, the problem is with the unit. Lets assume that the problem is inside the unit. In that case, the problem could be just a bad connection. If you can solder, check the main board around the speaker terminals for poor solder connections. If that is not the problem, update this and I'll provide additional things you can test and check.
Dan
Posted on Mar 31, 2008
  • ABRsvcs Apr 02, 2008
    A different speaker will work. The only thing I would suggest is that the speakers match. This is more to insure that the sound is consistant rather than a functional issue. Many speakers for these shelf systems are non-standard impedence values. The most common are 6 ohms. Both speakers should match in their impedence values at the very least.
    Dan
Speaker problem
first check if your phone is not on silence by going to profile settings on your phone. Also, check the phone volume to be sure it is not reduced to minimal.
If the phone is not on silence and the volume is set to the highest an problem is not still solved, then it means you need to replace the speaker.
Good luck.
Jan 04, 2012 | Samsung D780 Cellular Phone
I have a sharp tv with the volume at its highest but i can't hear anything
Hello
Check its speaker first. If voice coil of the speaker or tis cone paper has damaged, speaker will produce a dull low sound output. If the speaker is found OK, check the audio output section of the unit. This section circuits can be located inside the TV circuit board. look for any loose or bad soldering terminals at the audio output IC. It is best to resolder all the suspected solder points by applying a little more solder, withut making any solder bridge short in between adjecent solder terminals. If this also does not help you, replace the audio output IC. It is damaged. OK.
Dec 26, 2011 | Sharp 13VT-R100 13 in. TV/VCR Combo
I am using Sony Vaio VPCEA24FM. I have facing some issue with the sound . My laptop's right speaker is not working. I have checked the volumne balance and even lowered the left speaker volume and kept...
Hi....Just check the sound with stereo headset.If it is working properly ,right speaker has to be replaced.If the situation persist same before,you may have to check the motherboard .
Aug 12, 2011 | Sony VAIO Notebook
Hello! I'm having problems during a phone call with my speaker volume being too low unless speaker phone is on. All other sounds are loud & clear. I've tried resetting & turning the phone...
Did you happen to update to iOS 5? Because since the update. Mine has been the same way. The volume is very low. and sometimes even the speaker isn't too loud either unless I'm playing music.
If you did not update to iOS 5. Then your speaker might be blocked and easily cleaned with a cotton swab, or the speaker is just old and going out.
Jul 25, 2011 | Apple iPhone 3GS Black (16 GB)
Can't hear my speakers, but i can hear through my headphones
check the speaker connections, if you have a receiver that has front and rear,, switch the speakers to rear to make sure the speakers themselves are working correctly, by allowing the headphones to produce sound its letting you know the outputs for the receiver itself are good , also,, be sure that the speaker selection switch is ON and that its set for the correct speaker selection. (re front or rear or both) and that Mute isn't on
May 26, 2011 | RCA Audio Players & Recorders
Hi there, I have a pair of M audio BX5 speakers, one of them works fine, on the other hand, the other one sounds kindda funny. Both of the twitter and the 5-inch cone on it work, the main thing that's...
Little goes wrong with a speaker unless it has either been overloaded or subject to damp, extreme dust or has sustained physical damage from some sort of accident.
A rough test is to move the speaker cone gently through most of it's travel using an even pressure simultaneously on various places around the cone, I use my fingers.
It should move smoothly without any resistance and most importantly it should be completely silent through the largest or smallest movements.
If it sounds scratchy, the speech coil is either off-centre or it has suffered damp or dust and dirt has ingressed into the air gap or the chassis has become distorted.
If it is silent and electrically sound it should produce normal volume.
There was a time when loudspeaker repair, overhaul or adjustment was routine but these days it isn't economic except for the highest quality and replacement is best.
After gaining access to the interior wiring of the speaker cabinet I suggest further testing it by wiring it direct and leaving out the crossover if it has one.
Mar 23, 2017 | M-Audio Studiophile BX5 Main / Stereo...
I have a couple active phobic loud speakers, one is completely out of commission and won't play anything. The other will play sound but only through the tweeter, while the speaker itself does nothing. I...
The tweeter is working but the woofer driver isn't which will change the impedance (ac resistance) of your amplifier output. The other speaker isn't working which will again, change the impedance even more. This could eventually damage the I.C. amps should you apply too much volume to the speakers.
You can turn the volume up to normal listening level and with your finger, slightly press the cone on the woofer in and out a couple of time. Does it engage in sound when you do this? If so, the woofer's coil is damaged and the woofer must be replaced. No sound? Open up the speaker (stereo off) and make sure both wires are fully secured to the woofer. Should they be attached securely, your woofer is probably defective. Should you have a crossover network, you can obtain a good, known working woof and temporarily wire it where the old woofer goes, turn on your stereo (minimal volume) which can verify the network pcb (crossover) is working.
Apr 13, 2011 | Audio Players & Recorders
Low speaker even at the highest volume level for LG 9600
replace the speaker component, or just lift up the pin to contact to the PCB
Feb 18, 2010 | LG VX9600 Cell Phone
Speaker sound is very low
Open the master volume control window by clicking the sound icon on the right hand side of your taskbar(near your clock).and check the balance is set to low for your speaker or not.try to set it at centre.
or try to update your sound driver.
Mar 10, 2009 | Sharp Computers & Internet
Volume control unresponsive
The LED didn't turn on ,indicate the DC pwr was missing , you need to ensure there is a Dc supply to the speaker unit,once you got the LED on you will be able to control the volum.
Aug 09, 2007 | Harman Kardon HK695 Computer Speakers
199 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
