Question about GE JVM1650 1000 Watts Microwave Oven
Ge jvm1650wb005 I have a GE Spacesaver microwave oven that doesn't heat. Everything else seems to work fine. I just replaced the Magnatron, High voltage cap and diode. When this unit stopped working it would make a low hum noise fro 2 to 3 seconds and blow the 20 amp fuse. Now it seems to run correctly but doesn't heat anything up. Any suggestion would be appreciated.
  • 3 more comments
  • 2VCRSDAD Jun 20, 2008
    Me too! I have a GE Spacemaker Model JVM1640. It doesn't heat and makes a noise - not a hum - that seems to come from the fan area. The fan is turning, and there is no smell that would indicate the motor is running hot. Even if the fan motor is defective, would that be the reason why the food is not heating? If the fan was running at all, I could see why that would cause the manetron not to work. Also, I've checked the door switches, which I have read could be a factor, and they seem to be intact. But I don't know how to test them to see if they are ok. Any suggestions would be appreciated.
  • charliews Aug 11, 2008
    My microwave oven doesn't heat up,no hum.All other function work fine. Could it be a fuse or something thremo
  • deborahhenry Aug 14, 2008
    I have a GE JVM 1630 that no longer heats up ANYTHING. Any ideas?
  • billbenne605 Sep 06, 2008
    everything seems to work fine except it does not heat the food.
  • genehott Sep 10, 2008
    Yep, my quit yesterday. It moans a little different, but does not heat.
Weve had our fixed before and it's the heating element $75-$100 to fix.
Posted on Sep 01, 2008
  • 185 Answers
One of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Posted on Apr 01, 2008
2 Suggested Answers
SOURCE:
ginko
  • 19396 Answers
SOURCE: Ge jvm1650wb005
You need to have a repairman checking voltage out from power adapter. If PSU volts are OK, then probably you will need to replace the magnetron.
Posted on Jul 28, 2008
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Jul 28, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE profile JE2160SF03 microwave oven doesn't heat
3 things high heat low heat cencor or magnatron is bad
Apr 02, 2013 | Microwave Ovens
GE JVM1870 Runs, but won't heat up
use a high voltage probe to check high voltage, if present replace the magnatron if no HV replace the high voltage board this is the board that has the heavy wires to the magnatron
Feb 06, 2008 | Microwave Ovens
GE Spacesaver over the range microwave oven
GE Microwave ovens, and Microwave Ovens produced by GE but released under different brand names, have had several power problems for the past 20 years. Because it is so easy to sell parts and charge outrageous rates for repair GE never corrected the problems. They just continued it in the next model. They found that you would most likely purchase a new unit rather than paying $75. for a service charge, and $150. for labor plus parts (if out of warranty period).
Most failures were cold solder connections on the power relay board. These would come completely dis-connected after arcing and burning away the solder. Could be 1 month, could be years, but they knew it would happen. This power relay board feeds 120volts to the LV (low voltage) side of the HV (high voltage) Transformer. No High Voltage,,No cook. Everything seems to run normal, but if you listen carefully you will not hear the low tone from the HV Transformer. Over my thirty years in the business I have re-soldered rather than replace so many I couldn't count.
Next to that, a defective Magnetron.
Jan 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacesaver micro not heating
Your magnetron, HV diode, Capacitor, or control board maybe bad most of these components run with high voltage and difficult to test without the proper equipment
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Oct 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
613 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
