Question about Vacuums
The Connector that connects the power head to the hose is worn and does not make good contact. Where can I obtain these two parts.
  • Vacuums Master
  • 5,568 Answers
Please remember to give all the detail you can when posting a question.
Brand name and model numbers are essential minimums among these.
Posted on Mar 31, 2008
Power head not working
Check connection from hose to the main unit. Very important to make sure that the hose has a solid connection to the front of the machine. If not, then the receptacles can't make good contact to allow the power nozzle to turn on.
RainVac
www.rainvac.com
800-523-0510
Oct 08, 2012 | Rainbow E series Canister Wet/Dry Vacuum
I read the post about the Silver Moon continualy shutting off and requiring the new hose part SES 125. However, what i have noticed with my Silver Moon is that it only shuts off when using the floor brush....
Hi.
My wife has the same vacumn, and has already replaced the hose, and again it was shutting off continously with the power head.
Rather then spring another $150.00 plus for a new hose, I decided to take it apart to see if it had a shorted wire..
There are several small screws along the length of the control portion, as well as two small screws that hold the end cap (where the hose goes into the heavy plastic control part),
When I got it apart I did not see any shorted wires...however what I discvovered was where the hose "swivels" are 3 metal contact bands, and some electrical lubricant.
On the other side was a small circuit board with three paper thin copper contacts which lined up with the metal bands.
The bands looked a bit worn.
So I ever so gently bent the copper contacts out just a tiny amount further, and gently cleaned (with a bit of alcohol) the metal bands to take justy a tiny bit of what looked like an excessive amount of electrical grease.
I reassembled the unit...and so far so good.
Jan 15, 2011 | Miele s558 Silver Moon Vacuum
Need to find specs to test hose and electrical connections
There are no hose specs. You have continuity or you don't. These are very problematic canisters as they age.
Kenmore canisters are very subject to dirt build up on internal contact rings where they swivel at the elbow adjoining the vac.
They are also prone to intermittent connections at the handle/wand junction and at the wand/power head connection.
Due to the weight of the head there is a lot of strain on those connections.
You never fix half the connection, always both, male and female components in pairs for best results.
Oct 04, 2009 | Vacuums
GE canister vac 106766 power not going to brush head
Try checking the hose connector cord (short cord from bezel outlet to hose). Also, check the prongs on on extension wands.
May 19, 2009 | GE 106766 Bagged Canister Vacuum
Need replacement parts and can't find them
go to geyser vacuum center.com he has hard to find parts .i'm sure he can help you
Apr 07, 2009 | Eureka 6983 Bagged Canister Vacuum
Filter Queen Powerhead Not Working
is it the part where the hose connects to the wand or is where the wand connects to the power head? and what side keeps falling out. it sounds to me that its either a hose or a wand issue. unfortunatly the cord itself cannot be replaced and if the problem is a worn out connector in the hose which is possible it would require a replacement hose and if it is on the wand end it would require a new wand. either are fairly cheep on ebay. or you can possibly find one used at a local vacuum dealer. dont buy new. save yourself some money if possible.
Jul 22, 2008 | Filter Queen Majestic Canister Vacuum
I'm using Miele Medivac vacuum and I just sucked in a small plastic eye drop container by accident(I sometimes take off the brush part to **** in 'small enough' articles). And it is jammed in the part...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761462
Generic problem for all Vacuums
Posted by greenvanilla on Jul 09, 2008
I'm using Miele Medivac vacuum and I just sucked in a small plastic eye drop container by accident (I sometimes take off the brush part to **** in 'small enough' articles). And it is jammed in the part where the plastic hose connector bends. I think I can take it out if I can just disconnect the long necked plastic hose connector that connects the metal wand part and the hose part. Is it designed to be disconnected or should I not even try it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The long necked plastic hose connector is made to be replaced because they do brake upon occasion and the part is made to come apart. If you need assistance please contact your local vacuum cleaner dealer or to contact the Miele factory to get a owner’s manual to check the trouble shooting guide and or a schematic of the breakdown of how to un-install the
long necked plastic hose connector or gooseneck of which some people call it. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://miele.com/
Customer Service, Repairs, Parts 1-888-785-2828
Mailing address listed below:
Miele, Inc
9 Independence Way
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Hose connection broken.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=552957
Posted by nualaheaneyi on Apr 28, 2008
If you have a broken hose connection, and not knowing the brand name of the vacuum, I can suggest 2 things. If you have an electric hose, meaning that it is attached to a electric power head or power nozzle, some can be repaired depending on what was wrong, but most of the time you have to replace the hose, some pigtails can be replaced but if the electric connection is broken, you need to replace the hose. If it is a non-electric hose, you can use a shrink tube, or cut out the broken part and use a hose cuff to join them together, so just shorten the hose and screw back on the original ends. In either case you need to check with a local vac dealer. Or you can make a new hose with new ends and leave the canister @ the bottom of the stairs and go up with just the long hose, unless you have an upright then you have to make it the length that is on the upright. Or replace it with the genuine hose from the factory or use the ends from the old hose on the replacement hose. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
Blue moon works intermittently
Take the hose handle apart and look at the bottom side of the switch circuit board. Sometimes a contact or 2 break loose from the solder and will work intermittenly. Resolder the contacts if this is the case, put back together and try again.
Mar 16, 2008 | Vacuums
Powerhead for a fantom lightning
I have a good used powerhead and other replacement parts, but I think I read this a little late!
Feb 18, 2008 | Fantom Vacums Lighting Canister Vacuum
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
