Question about RCA RP5020 Digital Voice Recorder
Move recording to my computer
How do you move recordings from handheld to your laptop?
Plug it in, navigate to the files, drag them over. But the real problem then begins . . . now you must convert them to a playable file type and if you've got a mac you're screwed.
Posted on Jul 14, 2008
The unit is eating up the tape!
Generally speaking, there are two reasons this happens.
[1] tape recorders have to move tape past the record/playback heads at a highly consistent and accurate rate of speed. What makes this possible is a rubber "pinch" or pressure roller and a spinning metal spindle. Tape is routed between the roller and the spindle, and when the recorder is in RECORD or PLAY mode, the roller presses the tape against the spinning spindle, causing the tape to move from the feed reel to the takeup reel. When the pinch roller and/or the spindle become coated with oxide particles shed from old tapes, they get sticky and the thin tape will begin wrapping around one or the other. THE SOLUTION is to get some cotton swabs and rubbing alcohol and clean the oxide (brown from cheap tapes and dark gray from better tapes) from both of these parts.
[2] many tape recorders use rubber belts and pulleys to turn the feed reel and the takeup reel. If the tiny rubber belt that makes the take-up reel turn is stretched, it will not wind moving tape fast enough, which causes tape to bunch up. If this is the problem (you will not be able to see the belts without removing the recorder's outer case), then you might as well junk the recorder.
If you see that the part of the rubber drive roller that contacts the moving tape has a ring of brown or gray coating on it, you
Feb 19, 2010 | Sony TCS-580V Handheld Cassette Voice...
I have a scientific atlanta explorer 8300hd dvr that I want to offload the recordings to either an external hard drive or a pc or laptop''
The 8300DVR has a feature built in for outputting redcordings to a VCR. To output to a PC you will need a TVTuner card with RCA inputs. Pinnacle offers several products including a Hard Drive backup. You will follow these instructions below, the VCR will be your computer.
Copy a Recording to a VCR Tape
1. Connect the VCR to the OUT 2 connection on the back of the Explorer DVR.
See page 12 for more information.
2. Make sure that a tape is in your VCR and that the VCR is set to record.
3. Press List . The Recorded List
screen appears.
4. Press Move Up or Move Down
to highlight the recording you want
to copy to the VCR. Make sure to select
a program that is not currently being
5. Press Select . The Recorded
Program Options screen appears.
6. Press Move Up to highlight “Copy
to VCR.”
7. Press Select . The Copy to VCR
screen appears.
8. Make sure your VCR is properly connected
to your DVR outputs, and press
Record on your VCR.
9. Press Start copy A . The recording
begins copying to VCR tape. The
Recorded List displays the VCR symbol
for the recording that is copying to
Note: You can watch the copying in
progress through the PIP.
Mar 31, 2009 | Televison & Video
Olympus WS-100 Handheld Digital Voice Recorder I uploaded all my files onto my mac laptop and deleted them from the recorder. now when I turn on the voice-recorder, the screen says that "no...
Have you tried to go to the menu and format the voice recorder? This should reset the recorder back to its factory default settings. If that does not happen then the recorder may need to be sent for repair as Olympus would have to reimage the device.
Dec 05, 2008 | Olympus Computers & Internet
WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting the recorder to its original state. thankfully, i backed up the files on my computer first, so i didn't lose any data, although i did have to go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead, and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
Nov 28, 2008 | Olympus WS-110 Digital Voice Recorder
Olymp. DS-330,None of the Buttons respond at all,only hold slider
If you remove the batteries and reinstall, does the display indicate Hold at some point? The hold button sometimes breakes and doesn't activate the switch. Pop off the hold button and move the internal switch manually.
Nov 21, 2008 | VXI Corporation VTR-3200 Handheld Digital...
Recording in mono
I'm downloading ACL now to check the possible settings.  Double click the sound horn next to your time and click Options Properties and adjust sound for Recording.  Now you are in the recording settings window for Windows.  See what those options are.  Look at the bar on the top that has to do with line in and L/R  If it's greyed out and can't move it...your driver/card is only letting you record mono.  If it's gray like it's active and you can move it left or right then it's a setting in your ACL.  I'll be posting about that shortly
James Mac
Aug 26, 2008 | HP Pavilion dv9000z Notebook
Transferring a voice recording
Nevermind I found the solution myself! I switched the USB mode setting to MTP. It's been copied and moved over now.
Feb 14, 2007 | SanDisk Sansa e270 MP3 Player
RCA RP5020 Digital Voice Recorder Logo
139 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
