Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
PT-45LC12 Problem after startup
My rear projection tv is a bout 4 years old I just replaced the lamp ~5 months ago.
I turn on the unit and get a good picture for ~ 30 sec then unit shuts off with no warning. The lamp light is flashing 4 times then pauses then 4 times.........
Would love some help with this
  • 1 more comment
  • cdc411 Jan 17, 2009
    I have the same issue, the lamp indicator flashes 4 times every four times every 4 seconds. I cleaned the filter and took out the lamp. Looked at it and everything seemed to be Normal.
  • wsheehan Jan 29, 2009
    I replaced the bulb, yet the tv will not even display a picture.
  • kids2006 Feb 17, 2009
    I have the exact same thing. Does this mean the bulb is bad or is it something else? Thanks for the help!
  • Panasonic Master
  • 8,617 Answers
When the lamp flashes 4 times this is what the error code means IC 2301 pin 11 has detected an LCD error which is caused by an error in the LCD power CBA. which means the lamp voltage has become more than 130 volts or less than 30 volts. Or the lamp current is more than 5 amps, or the lamp is cracked. Its one of thos 3 reasons that will make the lamp indicator blink 4 times. Hope this helps. If you need the service manual for this model you can get one emailed to you from the following link.
http://servicemanuals.vstore.ca/
Posted on Mar 31, 2008
  • Andrew Bendorf
    Andrew Bendorf Nov 18, 2013
    Unless you tell me an actual solution to these issues it isn't helpful
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Pt-45lc12
It looks like a problem with a tube (projector light) I suspect the green one. Pay attention to flickering on the lights and post me the results.
Nov 01, 2007 | Panasonic PT-45LC12 45" Rear Projection...
The picture on my 13 yr old panasonic PT-51G44 ia darkening. Is this fixable or do I need a new tv?
Yes,the tv is fixable.When was the tv projection lamp been inside this tv was replaced in this tv,when was it the last time the bulb was replaced?The last time the probjection lamp was replaced about 1 1/2 or 2 years ago?The tv on an used at leat 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Aug 02, 2010 | Panasonic PT-51G44 51" Rear Projection...
Lamp doesnt look blown but lamp light flashing n tv wont turn on
Check the Lamp Fan if it is defective Lamp will try to light but will shut off, And the Ballast board is what turns Lamp on, For Part number o to Encompass parts distrubtion and type in your model they should list the ballast board and PN Then go to Ebay Look under Electronics type in PN, I got mine for $65.00
Lamp for $85.00
Jun 27, 2010 | Panasonic PT-45LC12 45" Rear Projection...
Lamp light out ?
Ck Fan behind Lamp first if it is OK then replace Lamp Look on E-Bay you can find lamps for as little as 82.00
Aug 06, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-45LC12......won't turn on
Its ballast supply issue that need to be replaced/ repaired.
Ballast supply drives Lamp in TV.
Jul 06, 2009 | Panasonic PT-45LC12 45" Rear Projection...
How to reset lamp meter
I have a PT-50LCX63 unit. After 5 years and 4 bulbs, a "reset lamp" warning showed up every time I turned on the tv. I have to say that after a few weeks, the message ceased on its own. I don't know if all models eventually reset or turn off, but I could not find any other information on the direct way of resetting. I find the warning a waste of time since the bulbs are good for 10 -14 months. Sadly I missed the class action suit that dealt with the premature lamp failures. I am looking for a new tv at this point. Bulbs have cost me $1200.00 since I bought it. The warning is supposed to allow you the option of replacing the lamp before it fails, Ha! what a joke...Thanks for reading.
Dec 29, 2008 | Panasonic PT-50LCX63 50" Rear Projection...
Resetting lamp replacement warning
Turn the TV on and press recall to clear the warning. Then hold down the volume " - " button on the tv and the PIP (Play) button on the remote for ~ 5 sec
Apr 03, 2008 | Panasonic PT-45LC12 45" Rear Projection...
My PT-45LC12 has picture and fan problems
More like lamp failure. Could be other things of course but start with the lamp cause it will need it anyway if has been a couple years.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Hope ya fix it!
Jan 10, 2008 | Panasonic PT-45LC12 45" Rear Projection...
PT-45LC12 wont power up
You have a bad lamp. The "clicking" sound you hear is the ballast (lamp power supply) attempting to start the lamp. The warning on Panasonics that comes up on screen does so when the life expectancy of the lamp is approaching. Otherwise your "clicking" sound and the red light on front are saying bad lamp. When you replace the lamp remeber to follow the instruction that Panasinc provides with the new lamp on restetting the lamp timer. This is usually done with the volume down on the TV and the PIP button on the remote.
Feb 26, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
337 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
