Question about Roper RGX4634KQ Gas Dryer
Roper dryer The dryer won't start, it doesn't make any sound at all. Just like pressing the start button with it plugged in. It has worked well for 6 years but just stopped the other day and now nothing. I checked the power and the outlet is getting power. Would it be better to just get a new one or to fix or have this one fixed. Thank you for any assistance that you can provide. Terrence
  • Anonymous May 09, 2008
    my dryer makes a clicking sound but will not start it is less than two years old
  • CMCM Jun 10, 2008
    how to open dryer top to check door switch
    Novelist:
  • 184 Answers
ROPER DRYERS ARE MADE BY WHIRLPOOL. ON ALL CURRENT DRYERS, THERE IS A THERMAL FUSE THAT WILL
DISABLE A DRYER IF AN OVERHEATING PROBLEM OCCURS. THE THERMAL FUSE IS GENERALLY A SMALL WHITE ITEM FOUND IN THE REAR OF THE MACHINE, DOWN
ON THE EXHAUST DUCT BEHIND THE BACK PANEL. THERE ARE TWO WIRES ATTACHED TO IT. IF YOU DON'T HAVE A METER TO CHECK IT, FIND SOMETHING THAT IS INSULATED
ELECTRICALLY TO SHORT THE TWO WIRES TOGETHER.
IF THE THERMAL FUSE IS BAD, THE DRYER WILL RUN WITH THE TWO WIRES SHORTED TOGETHER. REPLACE THE THERMAL FUSE. ALSO, CHECK TO MAKE SURE THAT THE DOOR SWITCH LEVER ISN'T BROKEN OFF. IT IS LOCATED IN THE UPPER RIGHT CORNER OF THE OPENING OF THE DRYER WHEN YOU OPEN THE DOOR. THE DOOR SHOULD
PUSH IT BACKWARDS WHEN YOU CLOSE THE DOOR.
TRY PUSHING IT WITH YOUR FINGER. YOU SHOULD HEAR IT CLICK. IF NOT, REPLACE THE DOOR SWITCH.
EITHER PART SHOULDN'T COST MORE THAN 30 DOLLARS.
Posted on Mar 31, 2008
Aeq6700fso dryer dryness button won't change the
E68 is a stuck button on th control panel
Nov 06, 2012 | Dryers
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
My dryer mod rex5634kq1 stopped working
what stopped? Does it not Spin? if so it could need a new motor. If it spins but doesn't heat up. it could just be a heat sensor in the back that needs to be replaced or a heating element. if nothing happens at all it could be the start button needs to be replaced. Turn the dryer around and open up the top back panel. should be about 6 screws. inside there will be a diagram on the schematics of the dryer.
Hope this helps.
Mar 27, 2012 | Roper REX5635E Dryer
Where is the the reset button on roper dyer
There is no reset button on any dryer. Your Roper is a Whirlpool with a different nametag. Depending on how old it is there may be 1 or 2 non resetable fuses. They are in the back behind the rear cover. They blow when there is another problem. Such as a clogged exhaust or a bad cycling thermostat. Don't do any work on it without double checking that the machine is unplugged
Nov 20, 2011 | Roper REX3614KW Electric Dryer
My dryer will heat but won't turn, I replaced the Dryer motor but it still doesn't turn. The door switch works fine, when I push the start button it clicks like normal and when I open the door I...
Have you looked for a belt on the drum of the dryer? Mine has a motor but it is attached to a wheel that turns large belt that extends around the drum.
Oct 03, 2017 | Roper Dryers
My roper dryer won't turn on. i rewired the back to put a new cord on and now it wont start
Here is a tip that will help you with changing your dryer plug.Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2011 | Roper RES7648E Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
My Roper dryer suddenly won't start. Was running
Is it gas or elec?
Have you checked the breakers?
Does the outlet have power?
Model# ?
Try setting timer in a different cycle.
Make sure door is completely closed.
Push door switch in manually does it click?
Please update lat me know what else I can do to help.
Ken
Mar 17, 2010 | Roper Dryers
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
Roper RGX4634KQ Gas Dryer Logo
200 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
