Question about Dell W3000 30 in. HD-Ready LCD Television
Dell W3000 lcd TV picture will not come on the first time power is turned on.
Dell W3000 lcd TV picture will usually not come on the first time power is turned on but will eventually come on after 2 to 8 times of turning it on and off. However, the sound will come on immediately and every time I turn it on. Once the picture comes on it stays on and the set works perfectly. Note that there is no consistency here. Sometimes it comes on the first time, sometimes it takes almost 10 trys.
  • MikeinCO Apr 01, 2008
    The TV is not new, I cannot take it back nor is it being used as a computer monitor.
    I can't perform this test. Any idea how much this replacement should cost?
    President:
  • 2,267 Answers
The failure on this Dell W3000 is found in the power supply assembly, specially around the 5VDC line due to dry or leaky capacitors. Their values should be 1000uF/16 volts. If you have a capacitance meter they can easily be found when you measure the value or you can see them bulging on top.
The audio is getting Its power from a 12VDC source that is why the audio works instantly.
Let me know if you need more assistance.
Posted on Apr 01, 2008
  • Jaime Hernandez Apr 01, 2008
    If you are unable to troubleshoot the power supply module. It looks like the only option is to replace the power module.
  • Jaime Hernandez Apr 02, 2008
    You can call Dell or inquire here for the power supply. It could also have a defective inverter boards.
    Genius:
  • 3,422 Answers
HI,
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Check the line cord. Wiggle both ends near the molded part.
TWO: Make sure you have power in the outlet by plugging a lamp into the same exact outlet.
THREE: Do a hard reset; merely unplug the line cord but leave it unplugged for 4 hours before powering up again.
The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If this does not solve your problem then the only solution to fix your the problem is to get it repaired by a technician
Goodluck,
Please don't forget to rate the solution.
  • 149 Answers
Common fault!!!!!!
if its new take it back..........
Posted on Mar 31, 2008
  • 818 Answers
Dell W3000 LCD TV has sound but no picture. In the past have had to turn on and off several times but this no longer works.
The problem of the picture not firing up right away on the Dell w3000 display is a manufacture defect in the LCD Inverter Boards. Could be master and could be slave that's failing. Most likely Master, but I suggest replacing both master and slave just to be sure. Stay away from pulled parts sold on ebay for this fix. You'll just be buying the same problem most likely. Try http://www.lcdparts.net/InverterDetail3D.aspx?ProductID=1921 I have ordered from them in the past they are reliable and handle RMA's quickly. This is a huge plus if you run into another problem trying to replace. They want 149.00 and the fix requires very little skill level to replace. Just have to decide if 149 bucks is worth it, or is it time to go for the 50 inch. hmnmm. Good Luck,
John Pritchett
Jul 16, 2011 | Dell W3000 30 in. HD-Ready LCD Television
W3000, power and audio but not picture
Yes I tried it and now I have nothing, not even a green light. So much for that. I have 2 of these sets. If you never unplug them from 110 I never have a problem. Un plug them and wait 2-3 days and nothing.
Any lawyers what to take this on?
Jul 08, 2009 | Dell W3000 30 in. HD-Ready LCD Television
HELP
mainboard is bad and needs replaced with the proper rev and firmware updates. questions, email me
Oct 27, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Dell w3000
Don't buy Dell TV's. I have been fighting this problem for years.
A royal pain. Now there is no red in the picture. All blue and beige.
My solution? New TV and ABSOLUTELY NO DELL!!!
Aug 11, 2008 | Dell W3000 30 in. HD-Ready LCD Television
DEL lcd W3000
Here is my suggestion.. sell it to me.. or I can ship you a new power board, a typical problem with these units. I have several power boards in stock (new). They are $129 each. If you are interested, email don@1stmile.net.
May 20, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Dell tv w3000
Try turning the master power on and off a few times. Give it a few secs inbetween power offs and that should work. It's worked for me. Sometimes it takes longer that other times to show a picture.
Nov 28, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Power want come on tv
Yes, I believe it is a power supply issue.... Problem is, I can't locate one
Oct 28, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Dell w3000 has green power on no video just audio only
Had same problem as described by others, green light, audio, but no picture. Decided to look inside. Layed the TV face down on three textbooks (1 at top & 1 at left & Right) so that back (9 large screws & 2 small screws) could be removed along with stand. From the power supply (board that 110v AC plugs into) there is a cable connected to a circuit board on the left (again looking from the back of the TV) covered by metal shielding. Unplug this cable clean the male contacts with a miniture wire brush (bought mine at Home Depot) & plug the cable back into the socket. With rubber gloves (just to be safe) plug the AC cord into the back of the TV & wall and turn on your TV. The bulbs should activate in 7 - 8 seconds. Reassemble the back of the TV & install the stand. Enjoy your TV Doug
Sep 08, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Dell W3000 30 in. HD-Ready LCD Television Logo
191 people viewed this question
Top Dell Televison & Video Experts
CoppellTVRepair.com
gwix50
Level 1 Expert
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
