Question about iLO DVD Recorder DVDR05
Ilo dvd recorder
Im looking for a remote control my unit works fine but i need a remote can u help
Try the philips brand from walmart SRU3004 it works most of he features. Must do manual code search and use the input button for source and the sleep button to get to the recording settings. Must use the eject button from unit itself etc. It is limited but does work for mine. Its like the 300th push to the power button in the code search so don't give up too early. I'm still trying to see if it will do more, got mine yesterday. After dozens of universal remotes I've tried, I was excited to finally find one that actually worked!!!
Posted on May 22, 2008
I need a remote for my ilo dvdr04 recorder. where can i get it?
Go to walmart and get a Philips universal remote, they have the ilo code listed. I have two of them...even though the remote isn't set up like the original ilo remote, you can still record, burn, finalize, and edit. I have the dvdrhd04...which is going into the shop tomorrow to replace the dvd burner, but the hard drive still works like a charm.
Again, you'll have to play with the remote a bit....ARC gets you into the menu and (.) while playing will get you into edit mode, but into another menu when not playing a recorded item. I've used it so much now that I can barely use the original remote. ha ha. The perk is that you can set up your dvd, your tv, digital box and other things to run on one remote.
Hope this helps.
Apr 11, 2009 | iLO DVDR04
I do not have my ilo dvd code for use with a universal remote control
if you still have your paper work for your universal remote, you may want to start there. Most remotes have an option that allows you to find a code...unfortunately, it doens't tell you what that code is. Most of the time it tells you to turn the unit on, and then set the remote up and then press the power button continually until the unit turns off and then you press set or enter. I've had to do that on several older remotes for newer equipment where I didn't have the codes. Look for instructions like that on your instructions...if you no longer have the instructions, try going to the remotes manufactures site. Philips has theirs online, and I imagine that most others would too. I hope this helps you!!
Feb 02, 2009 | iLO DVDRH04 DVD Recorder
Remotew control
I also have an iLO DVDRHD04. I recently purchased the Philips remotes at Wal-Mart and they have the code for the iLO. You'll have to play with it a bit, but all the functions will work, even though they will not be labled in the same fashion as the original remote. I had to just press buttons and make notes until I got it figured out...but it will work.
Jan 17, 2009 | iLO DVDRH04 DVD Recorder
Ilo dvd recorder do not recognize any dvd
According to that this unit is very picky on what discs it will record on. Look up unit and read the large number of reviews in DVD Recorder section
Dec 25, 2008 | iLO DVDR05 DVD Recorder
Almost no universal controls work on this unit. I only have found one out of dozens. Its a philips, code is 1906 but I tried it on other remotes and it doesn't work on them. Calling Leapfrog is probably your best bet.
Jul 04, 2008 | iLO DVDR05 DVD Recorder
No remote for ilo devd recorder
I finally found one that at least worked for the main features. It is a Philips URC from Walmart SRU3004. The guy there said Philips ones run the Ilo. After returning MANY ones that didn't work, I really didn't believe him but he was right. Its not the code listed, you have to do the manual search and it is like the 300th push on the power button so don't give up too soon. The input button operates the Source and the sleep button will get you into the record settings. you have to figure it out but allows you to actually use the unit. It is worthless without a remote. This remote actually works my tv, other dvd and home surround too.
Feb 05, 2008 | iLO DVD Recorder DVDR05
I need a new remote control. My remote control just stopped working.
Dec 16, 2007 | kawasaki PVS-10921 Portable DVD Player
DVDR05 player/recorder not-working?
Your unit would be defective. The control board on the front has went out.
Aug 15, 2007 | iLO DVD Recorder DVDR05
LVW-5005X DVD Recorder setup tv tuner
You have the wrong firmware,or cd is corrupted.These Liteon recorders have had some issues with the timers.The 5005xa can actually be transformed into the Ilo R04.Look on internet the Wizard has free firmware for your unit, look for iLO R04 which is almost identical to your unit.
If the remote is broke they are easy to replace ,if the recorder is a 5005xa the remote is a clone to ones used in the iLO RO4,used ones can be bought on Ebay for $10 to $20.If it is 5005XSA use the Liteon Rm 51 remote.The Gateway AR 230 recorder and some of the Akai remotes are clones to the Liteon5005XSA remotes.
Jul 10, 2007 | Lite On LVW-5005X DVD Recorder
ILO tv
you are not saying if it is with or without remote that you cannot turn up or down your volume please repost again for help.good luck.
May 14, 2007 | iLO V27DMBX Television
iLO DVD Recorder DVDR05 Logo
55 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
