Question about Sony KV-32S26 32" TV
No power T V just went dead and no power. checked fuse-ok noticed when plugging backm in a little arc. Isolated power board from the rest of tv and still an arc when plugging in. thanks jim
If you see a brief spark at the outlet when plugging in the power cord, this may be absolutely normal. It is the surge that happens when a modern switching supply is plugged in and that big capacitor charges up. If no fuses blow, and the spark occurs every time it is very likely normal. Some poorly designed supplies give a real arc-weld when plugged in, most just crackle a bit.
To the original problem, most newer sets have a small amount of power that is supplied to a microprocessor control board. If this small supply is out for some reason the set won't turn on.
Posted on Aug 05, 2008
    Scholar:
  • 135 Answers
Hi there!
Where you saw the Arcing, check closer to see wether the components are not loose on the board. You may only have to resolder the joints and problem solved. If the arcing takes place towards the tube, then you have a more serious fault. Thus involving High Tension, so I would not advise trying to repair that area if you are not familiar with TV repairs. Please unplug set before commencing any work. Regards and good luck, JUS004
Posted on Apr 02, 2008
Toshiba 32c100u dead; power supply board replaced but still nothing
Have you checked whether mains power reaches the power board? Check it first. If yes, the power board you purchased newly should be checked.
Jan 09, 2014 | Toshiba 32C100U 32 in. TV
I just got a free sharp LCD LC19SB27UT and it has a power problem, I opened it up and notice a fuse was dead, this all happened because a friend was using it in a thunder storm, I went to radio shack and...
on the power board you will see a black flat ac converter with this on it + ~ ~ - on it check this with a meter its more than likely to have gone as its the first thing to go in a storm. the + and - can be the other way round ~ ~ is the mains volts in and + - is the volts out if the ~ ~ has no resistance it has blown and it will keep blowing the fuse check the + - and you should have a resistance from the rest of the power board.
Jun 05, 2017 | Sharp LC19SB27UT LCD TV
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
I have aVizio VX42L HDTV10A. was watching a show when we heard a loud pop.Then all went dark. Would not turn back on. I took off the back cover and found the ceramic fuse was blown on the board # DPS-283AP...
This means you have a dead short, It is probably a Diode in the power supply area, but without testing board you don't know. If you know basic electronics, i would say check all diodes in power supply and look hard for something burnt and replace that also. Or just replace power board, check shopjimmy.com
Dec 08, 2010 | Vizio VX42L 42 in. LCD TV
MY VP42HDTV WILL NOT DO NOTHING WHEN I PLUG IT IN WHAT COULD IT BE.
Hi if you plug it in at the mains and switch it on and you get nothing not even the standby light then this points to either a fuse been blown so check the fuse in the plug failing that it will mean getting a new power board fitted, now if the telly is more than say 2 years old i would say its not worth getting fixed as the chances are you will replace the power board and then you will start having problems with the inverter, soyou could end up throwing money down the drain.
if its less than 2 years old and its totally dead check the fuse in the plug change it anyway and then give it a try but if its still totally dead then this points to either the fuse been blown in the telly this is a little clear glass fuse located where the mains cable plugs into the main power board, if this fuse is not blown also then the whole power board will need replacing.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | Vizio VP422 42 in. Plasma TV
Heard a pop then screen went blank. Now TV wont turn on.
Sounds like your fuse.
If not the fuse in your plug, then the internal fuse in the TV. to get too this you need to open the TV by taking off the back plastic panel and look at the fuse.
the fuse is the glass tube on the board, will no doubt be near where the power cord connects to the TV. and are easy to replace with another fuse. you will know soon as you open it if its blown as the little glass tube will be blackened or the little wire inside the tube will be missing or severed.
Fuses in TVs are actually designed to blow over time with ware (usually to last a bit longer then the warranty time frame) so after the cover has ended the TV can go in for repair work at extra cost. Its a little known fact.
Jan 02, 2010 | Sony KDF-E42A10 42 in. LCD Television
HITACHI 37PD5200 E Plasma dead.
The fuse is either open or it will have continuity do you have any standby voltages
May 14, 2008 | Televison & Video
LG RP TV wents fizz, now no picture or sound
The flyback transformer or the "spitter" has a problem and should be replaced. Figure on about $100 for the part(s) and the local labor charge as the cost. Call around. This is a simple diagnosis as the insulation has broken down in the part.
Dan
Mar 19, 2008 | Televison & Video
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
Sony KV-32S26 32" TV Logo
79 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
