Question about Lexmark X5150 All-In-One InkJet Printer
Hardware error 0502 on lexmark 3in1 printer
Does not printer. This error code just keeps coming up. What do I do?
  • c2smithyew Sep 23, 2008
    error keeps coming back, recently connected the printer to a win vista pc
    c:\program files\Lexmark x1151 series\lxbkjswr.dll
    any help would be appreciated,
  • 141 Answers
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
How to Perform the Hardware Test on the Lexmark X5150 ID:ENUS3744
Using the operator panel on the printer:
1. Press the Option button 10 times until Cartridges appears on the LED display.
2. Press the + button 4 times until Self test appears on the LED Display.
3. Press Select. The printer should print a sheet of paper with one black bar and one grey bar.
4. If the printer fails to print, remove both cartridges and try the test again. (It will feed the paper through and print a blank page.)
5. If the test works with no cartridges in the printer, run it again with one cartridge at a time installed.
Posted on Mar 31, 2008
  • Patrick St-Jean
    Patrick St-Jean Mar 31, 2008
    If this doesn'T work try this....
    Clean the rod that your carriage run might be dry and cause a error code ! You could put little bit of oil on it !
What does "Hardware Error 0502" mean?
The shaft that the ink cartridges travel back and forth on get buildup on it. If you clean it, your problem should go away...
Your answer and fix is here:
Jan 21, 2011 | Lexmark X6150 All-In-One InkJet Printer
Error message: HARDWARE PROBLEM ERROR CODE 0502 Only prints top part of page and then gives error code
Refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. If error continues even after following the steps, contact Lexmark technical support for additional assistance. Thanks.
Jan 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
Hardware error 0502?
Error 0502 can either be caused by a faulty cartridge or the encoder strip. Here's an article on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. Just click on this link: This should guide you on what to do when having this error. If error continues after following all the steps, don't hesitate to contact Lexmark technical support to further investigate the problem. Thank you for choosing Lexmark.
Aug 31, 2010 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X160 doesnt Copy or print faxes
I have been getting a remote fax error often enough that's it's becoming a nuissance. Any suggestions on how to fix this problem?
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X160 is not printing at all or receiving Faxes. The error that keeps coming up is Hardware Error 0502. Please Advise.
ok sir pls see the link this is the helpfull for the error 0502 in lexmark x160 all in one inkjet printer...ok
0502 error on my Lexmark All in One Printer
lexmark 5150 code hardware error 0502 what can i do
Dec 18, 2008 | Office Equipment & Supplies
Lexmar X5150 Printer whit Hardware error 0502, can you Help Me?
Download and install updated drivers from this link. If you need a walk through e-mail me your number and I will help you if you rate this fixya.
Jul 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark error message hardware error 0502
Clean the rollers that the cartridges run on with a non-lint wipe (i use non scented baby wipes for all my printer work. The printer should now run fine. cheers lilacgerry xxx
Jan 21, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
731 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
