Question about Car Audio & Video
2005 Ford Escape Factory CD Changer
When CD is playing it goes to check CD, then it will not load or eject a CD. Display does not show cdin or cd player. After a period of time it will eventually eject the cd in player and play alright for a while. Then do the same thing again. Sometimes when starting truck you can hear player trying to kick and will eject cd or not kick and go to radio.
  • pantherdunc Apr 25, 2009
    My CD player will not eject CDs. I have a 6 CD changer and it will not eject and will beep like it is going to load a CD when I select eject.
6ya staff
SOURCE:
Anonymous
  • 12 Answers
SOURCE: I have a factory fitted 6cd changer in my vw will not eject
Try disconnecting the power lead from the back of the head unit, wait 60 seconds then reconnect it. This should reset the head unit
Posted on Dec 27, 2009
Anonymous
SOURCE: Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Posted on Mar 23, 2009
Anonymous
SOURCE: stock 1997 Ford Explorer 6 CD changer stopped playing CDs
We finally realized that all of the "advisers" on the internet want to charge for their advice, and their advice in this case is univerally that the unit should just be replaced. Ya think?! Could of figured that one out on our own.....what a joke...
Posted on Apr 01, 2009
Anonymous
SOURCE: 6 cd changer
try to reset the cars computer. i had the same problem and it fixed it. all you need to do is unplug the battery for about 10 minutes and it may work. Good luck!
Posted on Jun 15, 2009
Anonymous
SOURCE: ford 6006e cd changer with e 3 error keeps happening
The only way to do it is to remove the radio using DIN radio removal tool - then you will have easy acces to remove cd's if you do not have this tools try to use coat hanger (do small catss on the ends)
(you can try to hold eject button and swich off - swich on button - probably it will not work but try few times
Good luck,
Kamil
Posted on Jun 24, 2009
Actually It is a Ford 2005 Escape with a Mach 300 audio system The serial number appears to be: 5L8T-18c815-CD largest letter in middle of label ODHC 001269 is the number in small letters close to the...
Can you let me know if the stereo is showing any message on the display? Is it asking for a code? I know the CD is not making a sound but is there any sound from the radio when it is tuned in? Are CDs ejecting correctly from the changer?
Was the work on the AC carried out in a shop?
I have some reservations as to whether this problem you are experiencing is down to a simple security code issue and will need some more information before I can advise further.
Many thanks.
Sep 23, 2011 | 2004 Ford Explorer
Help!! I have a library CD stuck in the CD changer. I can see it but it will not eject...it won't even acknowledge that it has a CD in the changer. I have tried tweezers, switching CD slots and trying to...
TRY TURNING OFF CD PLAYER.WAIT 10 MINUTES THEN TURN CD PLAYER BACK ON THEN PRESS THE EJECT BUTTON.SOME TIMES CDS PLAYERS GET HOT WHEN PLAYED FOR A LONG PERIOD OF TIME.MY CDS SEEMS GET STUCK WHEN I PLAY CD PLAYER LONG TIME.SOMETIMES IF CD DONT COME OUT .IF IT STICKING OUT JUST A LITTLE.TRY PUSHING BACK IN CD PLAYER THEN EJECT IT.THIS TRICK WORKS SOME TIMES.
Mar 11, 2011 | 2002 Ford Escape
I have a 2001 ford escape. The cd player won't play cds it won't eject or load them. All it says is cd error
You have a mechanism failure on the changer which is preventing the mode of the function to return to the normal state. Hence the processor is giving out the error signal. First of all open the changer and ceck for mechanism damage. if not slowl try to rotate the load motor to return to the normal state and eject. now check the connections to the motor, the flexible line wiring may be defective. use a loop wire or test the continuity from the motor. if there is a rest switch use it for resetting, if not disconnect poweer nd power again. Some cd'smay be warped or damaged and causing to block the sensitive transport. remove of these cd's and testt again. if there is no motr drive at all then the IC of the motor drive has failed. clean and set back. hope this helps you. Good day
Jun 29, 2010 | 2001 Ford Escape
MY 6 CD CHANGER IN MY FORD EXPLORER READS CD
hold in reset button with a pen tip for 20 secons
Dec 29, 2009 | Vehicle Parts & Accessories
2007 Subaru Impreza, the 6 CD changer will not play CDs and the display reads "Push Eject", but when I do push eject the cd is not ejected. None of the CDs will eject and none will play.The manual says I...
are there any cd's with homemade labels ,how many cd's are loaded?the dealer will recommend to remove the radio and send out for repair costing you a couple hundo or more depending on the problem if you're out of warranty,you'll also be out a radio until its repaired,if your factory warranty is still in they will just order an exchage unit and call you for install when it arrives. hope this helps,good luck!
Jul 12, 2009 | 2005 Subaru Forester
Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
May 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
2005 ford expediton 6 disc cd changer
06 expedition 6 cd player and having the same issues,,, Disconnect battery and all 6 cd are stuck inside. "Error cd" shows when pushing eject. Looked everywhere and nothing shows how to fix it. I dont want to buy another radio/cd player for something that ford should know and how to fix?
Nov 14, 2008 | 2005 Ford Expedition
There is a CD jammed in the cd player. (6 cd changer) It is a 2004 Ford Escape
It happens to me all the time on my 2002. Try cycling the load and unload buttons for the stuck CD location. If that doesn't work try ejecting the CD. When the slot door opens, try putting another CD into the slot and push on the edge of the stuck CD.
Jul 27, 2008 | 2002 Ford Escape
STUCK CD
you will have to remove and open the changer, and remove cd that way, hope this helps
Jun 22, 2008 | 2002 Ford Escape
Car Audio & Video Logo
923 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
