Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
LG7810 will not dry dishes
I not sure if the heating coil is out or what, but the dishes just dont dry anymore. I thought that maybe the Jetdry had clogged in the dispenser so I tried boiling it out and refillling it. Any suggestions. It is barely 2 yrs old and shoud be running like a charm.
    Novelist:
  • 184 Answers
THE DRY CYCLE HAS A PORT ON THE INSIDE OF THE DOOR WITH A BLOWER MOTOR. THE PORT SHOULD OPEN AND THE FAN MOTOR COME ON DURING THE DRY CYCLE TO EVACUATE THE STEAM FROM THE INTERIOR. THE PORT IS OPENED WITH A WAX MOTOR. IF IT FAILS, THE PORT WILL REMAIN CLOSED AND DRYING WILL NOT TAKE PLACE.
TO VERIFY OPERATION, WHEN THE DRY CYCLE STARTS,
WAIT ABOUT 2 MINUTES, THEN OPEN THE DOOR AND LOOK IN THE ROUND VENT ON THE INTERIOR OF THE DOOR. IT SHOULD BE OPENED. IT WILL SLOWLY CLOSE AS THE DOOR REMAINS OPEN. YOU SHOULD BE ABLE TO SEE THIS ACTION.
Posted on Apr 03, 2008
Samsung dishwasher sprays gunk all over my glasses. When the cycle is over they are coated with dried bits of gunk. Dishes are dirtier than when they went in.
I have the same problem with gunk and spots on dishes. I took apart the parts at bottom covering the heating element. There is all sorts of gunk on everything. I cleaned it all, even under gaskets and filter screen. I am neither sure what caused it nor how to prevent it. My thinking maybe the water source. Water in my town has gotten worse in quality and has bad smell. I use a major water filter system for drinking water. My thought is that the heating element is drying the water up and leaving sediment from water.
Sep 29, 2012 | Samsung DMR57LFS Stainless Steel Builtin...
Dishwasher not drying dished with any heat source. Dishes washed in cold water.
Most dishwashers are plumbed to the hot side of the hot water side of the faucet. This should provide hot water for washing the dishes. Perhaps this dishwasher was plumbed to the cold water side by mistake.
Most dishwashers have a heating coil most of the way around under the bottom sliding/rolling dish rack. The heating coil may not be working, which would be consistent with the dishes not drying at the end of the cycle. Possible causes include incorrect setting selected on control console (push buttons) or timer, heating coil disconnected from electrical source at one end or both ends, faulty control circuit inside the timer, faulty wiring between the timer/control circuit and the heating coil, burned or pitted contacts in the control circuit.
May 23, 2011 | Dishwashers
Yes I have a whirlpool DU1345XTVB1 dishwasher. Just got in July. After each wash cycle the dishes are not dry. I have been using Finish gelpacs w/jetdry & also have a off brand drying agent in...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Check your heating element.. </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">A bad heating element causes many problems in dishwashers&hellip;<br /><br />Dishwasher Problems The Heating Element not Working<br /><a href="http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not" target="_blank">http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not</a><br /><br />Dishwasher Maintenance<br /><a href="http://www.fixya.com/support/r4319937-dishwasher_maintenance" target="_blank">http://www.fixya.com/support/r4319937-dishwasher_maintenance</a><br /><br />heatman101 <br /><br />Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes <br /><br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 27, 2010 | Whirlpool 24 in. DU1050SS Built-in...
Dishes are not dry anymore after cycle?
Hello there:
If` you ahve already checked all of the filters and they are ok than your drying cycle has problems to check these check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat. there:
Normally if you have just started to have this problem and you have checked all of the filters and are sure they are ok than
Jul 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My kenmore HE diswasher, model number 665.1312 won't dry
is your heating element was working?,if working check the blower if working too.
Jun 04, 2010 | Dishwashers
My bosch dishwasher will not dry the dishes
this dw to save energy works this way- the final rinse will reach a temp of 161 F . the dishes have to absorb this heat. when the cycle is complete the dishes become a heater in themselves radiating the heat they absorbed during the final 161 F heat. If you have any tupperware or plastic dishes in the unit they will not absorb heat therefore not radiate the 161 f temp need to dry all the dishes. try to avoid plastic items and they must always have jet dry. this is the european way of conserving energy. on the old ge or whirlpool they had electric element in the bottom that would bake the dishes dry ....not these..but they do save alot of energy.. it helps right after a cycle to crack the door open release all the steam from the unit
Dec 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes don't get clean and don't dry
Hi reesbag
I'm Harvey the Master Plumber.
You're question is why the dishes don't get clean and it is not drying at all even though jetdry is full?
To begin with "jetdry" does not dry your dishes, It is a product that you can choose to use if you have a problem with spots on the clean dishes when the dishwasher is done.
Your problem is serious! If still under warranty then you're covered. If not and it has some years on it, it doesn't pay to throw good money after bad. If it came with the house it will be better in the long run to replace it. If you choose to repair, this problem doesn't lend itself to home handyman and it is likely in this case that after paying a repairman to come out you'll end up buying new anyway.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
205 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
