Question about Sony STR-DE475 Receiver
Protect Mode My receiver has gone into protect mode....just wondering how i can get it back to working order, have disconnected everything from it and even plugged it into a different power point but still comes up with "protect"
  • jekswan Oct 09, 2008
    I have the same problem. The display on the receiver is flashing "Protect". Surround sound is no longer working. Running the audio directly off the tv now because of it. Wondering if it is worth having receiver repaired or just replacing.
  • 4,234 Answers
Protect mode with nothing connected indicates an internal problem. Most likely one or more output transistors are shorted. This is a common problem with these and can easily be repaired by a shop for around $35 in parts plus the local labor rate. The output transistors are MN1620 and MP2488 (if memory serves me correctly).
Dan
Posted on Mar 31, 2008
My pioneer vsx815 is in protect mode i disconnected everything but the blue light continues to blink when i plug it in. What can I do to get it out of protect mode?
If you reboot the receiver with nothing connected to it except the power cable and it is still in Protection, there is an internal component that has gone bad.
Mar 25, 2016 | Pioneer Audio Players & Recorders
My Sony str de335 is in protection mode speakers are unhooked how do I get it out of protection mode?
if you disconnected everything and it still goes into protect, the most likely there is a damaged amp channel that will need to be repaired.
Feb 23, 2015 | Sony STR-DE335 Receiver
My Kenwood KDC-MP142 in protect mode. is there a reset button??
My kenwood is stuck completely in protect mode. I ve everything listed and it wont come out of it. So should i assume the unit has gone bad?
Oct 20, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
It comes on then protection mode comes on and wont go off allso i disconnected everything and it still stays on the screen
disconnect everything in the off state. Power on. Still in Protect mode? Then it is an internal fault. Service shop repair.
Mar 25, 2010 | Sony STR-DB830 Receiver
Shuts down in protect mode
disconnect all the speakers and turn it on. if it does not go into protect mode, then youve got a bad speaker or wire. good luck
Feb 10, 2010 | Sony STR-DE597 Receiver
When i switch on my samsung HT-Z110 the word hello appears then protect thenit turned off!
Audio receivers have an output protection circuit called "protect mode", this is to protect the receiver from short circuit failures.The speakers and speaker wires are what I inspect thoroughly first, look for bare speaker wires,or bare wires that are touching each other at that point,check speaker wires at the back of the receiver for sloppy connections,etc.If all looks good then try disconnecting all the speakers at the receiver,then turn power on to see if it goes into "protect mode", if it does the the receiver probably has an internal short and will need to be sent in for service,if it doesn't go into "protect mode" then connect one speaker at a time back into the receiver until it does go into "protect mode" then which ever speaker you connected last is the speaker that is shorted(blown) and then you know that speaker is the problem and it will need to be replaced or repaired. Good luck !
Nov 29, 2009 | Samsung HT-DB600 System
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Unit goes into protect mode
Not unless you know how to troubleshoot solid state electronics. If you disconnected the speakers and the unit still goes into the protect mode, most likely you have a short in one of the power output stages. Good Luck
Jun 03, 2007 | Marantz SR-4200 Receiver
Sony STR-DE475 Receiver Logo
205 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
