Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony 20" TV controls problem
Picture is fine, but volume stays at loudest point even when I try to reset it, and can't change channel using either control on front of set or with remote
  • 88 Answers
Try to disconnect your power inlet cable 110v within 5mn to make a big reset and restart your tv and reconfigure all
Posted on Mar 31, 2008
SOURCE:
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Hi my sony bravia kdl-46v4100 model is decresing sound before i use 20% volume to hear it but now i use 40% of volume. What should i do? Can you guys help me? Thanks!
It's probably a station channel, channels broadcast different picture and sound quality, therefore when changing channels this can be noticable. It is probably not a tv problem.
Jul 02, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Sep 14, 2009 | Aiwa TV-S2011 20"
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My digital comcast remote will do everything except change the channel on my magnavox TV. Volume/power control is fine. How can I fix it?
your tv needs to stay on the same channel for the cable box to work with the tv and you change the channel on the cable box not directly on the tv
Jun 12, 2009 | Philips Magnavox 20MC4304 20 in....
Television: no picture, good audio
screen control is too high
Nov 11, 2007 | Televison & Video
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
