Sony KP-61HS10 Rear projection Have this Sony bought in 2000, picture is very blurry with lines going accross it. Gets better at warmup but then it goes again. When I pull out my monster component plugs and put them back in, it goes away for awhile then returns. Is this set worth fixing, much nicer newer ones on the market but I hate to get rid of it without giving it one shot to see if it can be fixed. thanks.
Hi gud day! your problem has a solution. Just try to fix your tv from blurry picture. Pull the socket at hte back of the picture tube. remove the socket from pcb(printed circuit board) de solder the pins. then after that, if you see a 2 metal formed like a small mountain facing each other, try to clean those remove the rust (green color) using sander or any material you can use, just avoid using oil on that bcause it is sparking. then try to install it again and try to turn on your tv. if still not working replace that socket with a new one. you can buy it at any electronic supply store. and re install then on it again.. surely it will fix your tv without expensive components.
be sure unplugging the tv from ac souce before disassimbling...
thanks,
janex
