Question about Indesit W 123 Front Load Washer
Indesit W123 washing machine
When push in 'on' button the red light comes on and stays on continuously but the machine wont start the programme. Usually when first put on the light flashes a few times and the machine begins to fill. Today it wont fill or start, just sits there with red light on!!!
  • Anonymous Sep 01, 2008
    hi i have the very same problem
  • 67 Answers
It maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
Posted on Mar 31, 2008
When i Press start the washing machine clicks a few times then red padlock light comes on. Door interlock changed but still happening. Any help appreciated.
I gather that the interlock has been replaced and now the padlock symbol lights up plus some clicking. I think the clicks are the door lock engaging and the padlock just shows this. Do the clicks continue? Does the door stay locked? If so I believe you have a fix.
May 19, 2015 | Indesit Washing Machines
When I programme my washing machine the lock light does not come on when the door is closed, therfore it will not start.
Possible that the DOOR lock SWITCH is faulty and so the continuity to the switch and the wiring to the panel must be checked.
If there is no continuity then the switch must be replaced.
Jan 15, 2013 | Indesit W 123 Front Load Washer
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
Replace door rubber W123
how do I replace the door rubber on Indesit W123
Oct 26, 2008 | Indesit Washing Machines
Faulty washing machine w123
does the water empty from the machine? if not you will more than likely have something trapped in the pump. the best thing to do is run the grey outlet hose into a bucket, this will empty the machine. then tilt machine back (make sure it wont fall) then remove the plastic kick plate on the front bottom, behind this you should see the round plastic filter this will unscrew and pull out, you may need a couple of towels put on the floor as there is usually water left in the pipes. clean any debris and screw filter back in, should only need to be hand tight. replace kick plate and then give it try.
hope this helps
kj
REMEMBER MAKE SURE POWER IS OFF BEFORE CARRYING OUT ANY WORK.
Nov 09, 2007 | Indesit W 123 Front Load Washer
Indesit w123
possibly the heater. take bottom back panel off and check continuity across the heater bottom rhs
Jul 08, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
445 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
