Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice chute door
Does anyone know where I can find a schematic to put the ice door back together? Can't see too well in the tiny space and wondering if the faceplate to the ice and water service are snaps off. Don't want to break it...
    Novelist:
  • 184 Answers
THE FACE PLATE OF THE DISPENSER ASSEMBLY SHOULD HAVE A SLOT ON THE BOTTOM CORNERS. INSERT A LARGE BLADED SCREW DRIVER IN THE SLOTS AND TWIST. IT WILL SNAP AND YOU WILL THINK YOU HAVE BROKEN IT BUT IT DIDN'T. ONCE THE BOTTOM IS RELEASED, PICK UP ON THE FACE PLATE TO DISENGAGE IT FROM THE TOP OF THE ASSEMBLY. IF YOUR DOOR FELL OFF, THE CHANCES ARE THAT A PLASTIC LOOP BROKE OFF THAT THE HINGE PIN SLIDES INTO. A FIX KIT HAS BEEN DEVELOPED TO REPAIR THIS PROBLEM. BEST TO BE INSTALLED BY A FACTORY AUTHORIZED SERVICER. IT CAN BE DIFFICULT.
I HAVE INSTALLED TWO OF THEM MYSELF.
Posted on Mar 31, 2008
SOURCE:
My ice in the ice maker seems to be melting together and they are fusing into big ice cubes that cannot dispense/
This tends to happen when ice has sat in the ice bucket for a couple days of non use. The warmer your kitchen the worst this tends to happen. What's usually happening is the ice bucket is sitting on the door where the ice dispenser sends it to your glass. Since the cavity in the door is exposed to the warm air in your kitchen it can work its way to the ice bucket area via the chute in the door and when the moist warm kitchen air reaches the ice cubes in the bucket it turns everything into melting ice cubes which eventually freezes at some point and clogs up the ice bucket with large globs of ice pieces that the ice crusher can't handle. About the only thing to do is remove the ice globs from the bucket and make new ice. This is not all that abnormal, just a pain though. Try putting something in the chute (small Rag?) to see if this stops it. If it does then there's not a whole lot you can do about it but use the ice machine more often so it doesn't all sit there melting together.
Sep 25, 2014 | Samsung RFG237AARS Bottom Freezer French...
I have a Frigidaire Gallery French Door (bottom drawer freezer) with a Water/Ice Dispensor in the door. The Ice dispensor works intermittantly. The Ice chute door always clicks open but sometimes it...
Cold is not the problem. The board or the wiring going to the board is defective or just has a bad connection. Because it worked while you held the board a certian way points to a break at the plug going to the board or a break on the board, Sea Breeze
Sep 25, 2013 | Frigidaire FRS23KR4AW Side by Side...
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice in bucket freezes into a lump, mechanism freezes
it sounds like the ice chute door is stuck open. on this model it can slip off the "hinge pin" or the plastic that holds the pin can break. if the flap is broken it is replacable. the pin can be put back in. if the plastic that holds the pin is broken, you need to replace the whole door. expect to wait 6-8 weeks for a new door, sooner if lucky. cost is $400 +++ more for stainless.I hope the pin fell out. hope this helps
Jun 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice Chute door dislodged
IF THE ICE DOOR HAS COME OFF, THE CHANCES ARE THAT THE PLASTIC TAB THAT HOLDS THE HINGE PIN IN PLACE HAS BROKEN. IT IS PART OF THE PLASTIC HOUSING. WHIRLPOOL/KITCHENAID HAS A FIX KIT THAT REPLACES THE PLASTIC TABS WITH A METAL BRACE THAT IS PRESSURE TAPED IN PLACE. I HAVE INSTALLED A COUPLE OF THESE KITS AND IT TAKES PATIENCE AND TIME. THE KIT WILL HAVE INSTRUCTIONS ON HOW TO INSTALL. FIRST VERIFY THAT THE TAB HAS BROKEN. IT IS LOCATED IN THE UPPER LEFT SIDE OF THE OPENING TO THE ICE CHUTE.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker chute door
Here's a location for a schematic to let you see what's all inside there. http://www.partselect.com/Schematics/Whirlpool/VM1P3RPM.gif
Dec 27, 2006 | KitchenAid Superba Architect KSCS25INSS...
Frost on Ice Maker shute
Dtot, does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Whirlpools where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Whirlpool and inquire about the aforementioned. If this is your case, there is a good chance they will cover it. Catriver..post back.
Oct 21, 2006 | Whirlpool ED2FHEXN Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
94 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
