Question about Toshiba 43H71 43" Rear Projection Television
Problem with tv
Blinking powerlight no picture or sound cannot pull up the menu screen looks like the tv is in a lock mode
    Genius:
  • 1,694 Answers
If your Model is Tosh 43H71,then pull chassis and locate F850,
F851 soldered-in fuses...check with meter..if open,replace with
proper value micro fuse(s) and solder jumper wires 008,010,017,
048,600 located on signal board.Replace convergence IC's
STK392-110 with IC's from kit # X 480295 ( upgrade )...........T.
Posted on Apr 04, 2008
I have a picture menu lock mode on my screen how do I get that off to exit this mode and how do I program my TV can't get into menu
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Feb 23, 2016 | Televison & Video
How to enter in server mode in 21rf vardaan crt tv?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
You should have its original remote control to enter the service mode. No universal remote control will go.
Aug 16, 2014 | Televison & Video
When turning on in morning can't get out of menu mode. Once it warms up for about 15 minutes it works fine, but starting to blink into menu mode more frequently. In the morning you can click menue on the...
Possibly could be the remote, the only way to find out is to pull the batteries out and leave them out for a while to see if it does it will the batts are out of the remote
Dec 09, 2010 | Philips 42PFL5332D 42 in. LCD Television
No picture No audio
Replace the lamp.
Nov 01, 2009 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Blinking powerlight on front when i try to turn on tv
This is more likely a power supply failure. Most causes of tv failure are due to bad capacitors on either a system board or the power supply. In this case, it sounds like the power supply. You can test the capacitors with a capacitor tester to determine faulty capacitor. You can also test other components like power supply current with voltmeter or mulit-tester.
Aug 13, 2009 | JVC AV48P777 Television
Panasonic T.V. "Picture Menu Lock Mode"
On my 27" you need to press action and the channel button at the same time to unlock. Hope that helps!
Jul 22, 2008 | Televison & Video
No picture on TV with powerlight on
If you press the power button *on* your TV (rather than using the RC), does the power light still stay on red rather than turn green?
Jan 05, 2008 | Televison & Video
No picture, sound OK...setup menu shows up, able to get picture in PIP
You will need to check the inputs on the television. You more than likely have a bad video in signal. This can be a bad cable or a loose connection either at the input of your television or at the output from your receiver, (cable or satellite). First, try wiggling the cable and then try replacing it. This should fix the problem. If not, your signal may be routed through a stereo or other switching device?
Apr 17, 2007 | Samsung PCL541R 54" Rear Projection...
Toshiba 43H71 43" Rear Projection Television Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
