Question about Refrigerators
Have a Whirlpool ARG585 A built in fridge which very now and again it will freeze up or the food will can you help?
Sea Breeze
  • 4655 Answers
SOURCE: food in bottom drawer of fridge freezes. what is the problem?
Try adjusting the food compartment temp. There are many possible reasons that will cause this. Look for exact model number located inside food compartment bottom door when opened. For example 91.802574 This will give us the exact diagram to work with to help you solve this. Below is a link with Q&A that you also can use to resolve this problem.
Let me Know and Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
  • 400 Answers
SOURCE: Liebherr fridge 3150 keeps freezing
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Posted on Mar 05, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool FRIDGE actually FREEZING items.
Howard,
Your defrost system has gone out. Check your heaters first then the
t-stat and timer. We have parts so if I can send them to you, please give us a call. Hope this helps! Ella
Posted on Aug 18, 2009
woodchuck789
  • 4070 Answers
SOURCE: My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Oct 10, 2009
I have a whirlpool fridge with a bottom freezer. The freezer is not freezing the food and the fridge is not keeping the food cold enough.
Try cleaning the condenser coils and see if that helps.
A little more information on the process in the link below.
May 11, 2015 | Whirlpool Refrigerators
My whirlpool fridge is freezing the food in it. What can cause that and how do you fix it?
set at minor temperature,set the thermostat dial at warm temperature.maybe its a little bit empty of food and at full coldest settings
Jul 15, 2014 | Refrigerators
My whirlpool fridge is freezing the food in the fridge. What is causing that?
adjust the temperature settings.change from coldest to colder
My LG 693 LTR fridge freezer model no P247STSL is freezing the food in the fridge and building up ice in the fridge on the left side of the drawers on the wall on the side of the freezer, sometimes the fan...
The reason why fan is making loud noise is because of the ice built up on the coil because of freezing.
You can check your drain line to see if it's clogged and clean it out .
There are several video on you tube showing you how to clean drain line.
Hope this help
Jun 02, 2017 | GE PSS25SGN Side by Side Refrigerator
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have the same problem .i took apart the inside of
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Some manufacture designed kits to help and some home made remedies. http://www.applianceaid.com/defrost_drain_freezes.html
click the link given above
Mar 02, 2009 | GE GTS12BBPLCC Top Freezer Refrigerator
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Freezer not freezing food and fridge not staying cold enough
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
