Keyboard keys the question key when i press it comes out ? other keys are similar how can i fix it
  • 2 more comments
  • Anonymous Apr 25, 2008
    I have the exact same problem, and my regional settings are set to english. I even removed all french and multilingual options from the list. I really HATE this keyboard! This happens a lot, and I donèt know which buttons to press to get it to stop!
    apostrophe = è
    quotations = è
    question mark = é
    backslash = é
  • ikayla2006 Dec 16, 2008
    That exact thing is wrong with my computer keyboard, have you found a solution to this proble.
  • Anonymous Jan 15, 2009
    problem with w+w+++++++++++++++ its comes automatically when i press w+w+++++++&q+++++++++++++++++.
  • Anonymous Feb 22, 2009
    This is causing my computer to load and run very slow
  • 293 Answers
Check your setting on the control panel regional settings select language tab then details check the keyboard settings it should be english us
Posted on Apr 01, 2008
I type j and it comes out 1. can't fix.
Try this.
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times. does it help?
I think your numlock might be stuck on and your keyboard "num lock" key isnt working
Jan 04, 2011 | Computers & Internet
How do I use the function keys to engage the battery charge function - specifically what is the fn key? I don't see in on my keyboard
The function keys are toggled between their different jobs by a key labeled F lock or there is a fn key at the bottom of the keyboard. I was not able to see a keyboard layout for your model, but look for a key near the <alt> <windows> and <ctrl> keys that says fn or the like. It functions similar to a capital letter, press and hold the key, and press the desired function key.
Nov 19, 2010 | Dell Inspiron 1525 Laptop
How to work f keys on top of keyboard?
if your on a laptop.. see if you can notice a "function" key.
this will enable he f keys on your laptop keyboard.
If you are using a PC desktop and have either a MS keyboard or something similar, on the keyboard, you should see a "F" or "F-Lock" key. Press this and you F keys will have functionality on keyboard.
good luck ...
Sep 28, 2010 | Computers & Internet
Is it posible to disable the scroll lock
Yes, all you have to do is press the Scroll lock button. You have not specified what brand is your laptop but I can still explain you. Laptops have small keyboards thats why they use an additional key called "Fn". It works like the Shift key.
If you press Shift + the .(dot) key, for example, it will print >. Similarly, you press a combination of Fn and other keys for different things. Look for "ScrLck" , "Scroll" or similar on your keyboard. When you find it press Fn + that key to disable scroll lock. Hope that helps.
Apr 05, 2010 | Acer Computers & Internet
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Feb 22, 2010 | Casio Music
Key board problem
Try to press Fn key, hold it down and press the Numlock key.
Jan 16, 2010 | Velocity Micro NoteMagix x30 Laptop
I'm sure you've been asked many times--how do I turn the numeric key pad on/off?
Look for a key labelled Num Lock or something similar (perhaps an arrow with a number inside). You may have to use shift or the fn key to toggle it. please vote.
Nov 04, 2009 | Matias (FK103) (DRB7022OXKB) Keyboard
The @ key does not work
either ita a dirty contact under the key or its failing, proberly easy to replace keyboard, or give it a clean up
Nov 18, 2008 | Computers & Internet
Laptop keyboard problem
check to see if the "Fn" button is stuck down, it sounds like the keystrokes you are describing are some shortcut keys to provide adjusting functions for the laptop facilities. Turn off the laptop, disconnect the power adaptor, disconnect mouse etc... and pick up the laptop and give it a gentle tap from behind the machine, and also go through all of the keys and try to press them and you may find one or more are stuck down (in particular the Fn key or similar).
May 04, 2008 | Razer Tarantula RZ03-00070100-R2U1
Installing Win XP, F8 key to agree to EULA wont respond
Check for an F Lock key on your keyboard.
By pressing it, it should activate your F Keys and F8 should work as advertised.
Nov 18, 2007 | Computers & Internet
Computers & Internet Logo
434 people viewed this question
David Payne
David Payne
