Seagate 80GB storage. drive not found. lite on front of drive blinking
  • Rajkumar Bordoloi
    Rajkumar Bordoloi May 11, 2010
    plz give all the machine specs.
  • Stuart
    Stuart May 11, 2010
    Is it an external USB type.?
    Sergeant:
    Champion:
  • 293 Answers
Check your usb cable from 80gb hard disk to the pc.
is the 80gb hd detected by the pc? what os you are using for the pc? check the external hd inside maybe it is not properly connected
Posted on Apr 01, 2008
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Computer does not read mextor hard drive
Dear kenarone,
May I ask you to install this software from Seagate to verify the status of your external hard drive:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
Once tested, if there is no physical fault reported, the issue could be a corrupted Master File Table. If that is the case, may I ask you to try with a Recovery Tool like OnTrack Data Recovery Lite:
http://www.ontrackdatarecovery.co.uk/data-recovery-software/easyrecovery-lite/
If that does not allow you to recover any file, May I ask you to format the unit completely with this guide:
http://www.ehow.com/how_6026_format-hard-drive.html
Regards,
Eddie Knight
Dec 28, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Hi, My Seagate 80GB IDE HDD is not detected in BIOS. But the drive is spinning. Is there any way I can recover my data?
If data in your hard drive is really important to you, try to look for a similar model hard drive. Then swap the logic board of the good hard drive with the defective hard drive. If the cause of problem is the logic board, then your hard drive should work by now. If you are not that technical, you can ask a technician to do this for you. You can buy a second hand hard disk for a few bucks at ebay.
Dec 28, 2010 | Seagate HD-ST380215A Barracuda 7200.10...
Hi, I need a SEAGATE MOMENTUS 5400.2 ST98823A 80GB
check with a good local computer shop. WE (fixya)have no idea who might sell those parts
Nov 02, 2017 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
My seagate momentus 5400.2 external hard disk can't be detected by any computer. doesnt show up in the device manager, or anything. the light is on, for some reason, sometimes it blinks red/green,...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
WD drive won't work as master when Seagate 80GB drive connected as slave.
The jumpers on the Seagate must be set to slave.
otherwise they are conflicting for the Active partion and bootloader.
Regards
Richard.
Apr 26, 2009 | Western Digital Caviar WD200BB 20 GB Hard...
Computer shutsdown completely when i insert my 80gb seagate barracuda 7200 HDD
What operating system are you using some can only recognize up to 10GB
and is the 80GB fitted correctly
stripe on cable to No1 pin on M/board socket and toward the 4 pin power socket on hard drive
Oct 27, 2008 | AMD ASUS A7V8X-MX ALL IN ONE MOTHER BOARD...
Seagate 80GB external drive - drive lost. Lite on front of drive continuously blinking
If you plug it in to a hub try plugging it in to a USB port directly instead, one on the front or rear of the PC.
Mar 31, 2008 | Seagate FreeAgent Go 80 GB USB 2.0 Hard...
Seagate 9w3638-556 100 gig usb drive working fine then blop front led is just blinking
Check the drive end to make sure it has poer and connectors are sound - you have he to take the case apart for this Change the USB connector for another asl anothercable is possible Go to Start/control panel/admintools/computer management/storage/removable storage See if the drive shows up
Jun 02, 2007 | Seagate (ST9100801U2-RK) (9W3638556) 100...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
