Question about AT&T 8925 Tilt Smartphone
Bluetooth My Bluetooth isn't pairing. It all worked yesterday, i un-paired everything since it wasn't connecting today and tried to re-pair, my evise isn't finding anything.
  • MelisaH Apr 03, 2008
    Thanks. It worked.
bluetooth - f82dfbc.jpgYada yada yada
Posted on Apr 07, 2008
    Problem Solver:
  • 5 Answers
Have you reset any registry settings on the phone ??
I suggest you do a hard reset on your phone ; remove the device from the item you want to pair it to and then do the whole thing again..
revert if this doesnt work
Posted on Apr 03, 2008
SOURCE:
When I am trying to pair my smart phone with my ISBW2113 speakers I am getting an error: Unable to pair with ISBW2113. Incorrect PIN or password?
default is usually 4 zeros
yep it is. You must only have one entry on your phone for them. Manual is listed, details on page 2.
Pairing the Speakers (This process should be done FIRST before pairing a Bluetooth device. This should only need to be done upon first use.) 1. Power on the speakers by sliding the power switch to the ON position on both units (first make sure both speakers are fully charged). The Bluetooth Indicator and Speaker Connection Indicator will flash slowly in unison. If the Speaker Connection Indicator is not flashing, but is solid white both speakers your speakers are already paired. You can skip to the Pairing a Bluetooth Device section. 2. Press the Connect Speakers button on both speakers simultaneously. The Speaker Connection Indicators will flash quickly. Wait until both Speaker Connection 3. Indicators are solid white, this means the speakers have been successfully paired. Please note that this process can take up to 1 minute. Note : For all future uses please turn on both speakers and wait for them to connect (it may take up to 1 minute for them to pair automatically even after initial use). There should be no need to press Connect Speaker button again. If any pairing issues should occur, please follow the above steps again. Pairing a Bluetooth Device 1. Make sure you have first followed the instructions for Pairing the Speakers
When pairing, the device should remain within 3 feet of the speakers. 2. Press the Pair button on ONLY one of the speakers. The pair indicator will begin flash quickly. Using the native controls on your Bluetooth device, select the "ISBW2113" in your Bluetooth settings to pair. If your device requests a password, enter the default password " 0 0 0 0 ". Refer to the user's manual for your specific device for instructions on pairing and connecting Bluetooth devices. 3. When successfully paired, the pairing indicator will stop flashing and will remain solid. After initial pairing, the unit will stay paired unless unpaired manually by the user or erased due to a reset of the device. If your device should become unpaired, follow the above steps again. If any pairing issues should occur, un-pair the unit on your Bluetooth device and follow the above steps again. Note : If two speakers with the ISBW2113 name appear on the pairing list of your device, please erase one of ISBW2113 listed in your Bluetooth device and repeat the above steps again. Para descargar este Manual del Usuario en ingl?s, espa?ol y franc?s, o para obtener respuestas a preguntas frecuentes, visite la secci?n de apoyo en www.iLiveElectronics. com Playing Audio Wirelessly 1. Follow the instructions for Pairing a Bluetooth Device. 2. Use the native controls on the connected Bluetooth Device to select a track. 3. To play, pause or skip the selected track, use the native controls on the connected Bluetooth Device. 4. Any audio played through the connected Bluetooth device will now be heard through the speakers. Pour t?l?charger ce guide de l'utilisateur en anglais, espagnol ou fran?ais, ou pour obtenir des r?ponses ? des questions fr?quemment pos?es, consultez la rubrique d'assistance sur www.iLiveElectronics.com Customer Service: 1-888-999-4215
ILive ISBW2113B User Manual Page 2
Jul 04, 2016 | iLive ISBW2113B BLACK WIRELESS BLUTOOTH...
Why cant i get my computer to dicover my auvio pbt200 bluetooth speaker?
  1. Try playing other audio files. Ensure that audio can play fine from the same audio device when using a headphone.
  2. If Step 1 is not the case, try listening to audio by connecting the speaker to the Bluetooth device using the Aux-in cable. This will isolate if it's a Bluetooth connection issue or not. Remember to disconnect/un-pair the Bluetooth connection first.
  3. If the issue only happens when connecting via Bluetooth, do the following:
    1. Adjust the distance between the speaker and the Bluetooth device.
    2. Reset the speaker to its factory default settings. For instructions on how to reset your speaker, go to the product's support site to view the relevant knowledgebase article.
    3. Clear the current pairing entry from your Bluetooth device. For instructions on how to clear the pairing entries, consult the user's manual of your Bluetooth device.
    4. Try re-pairing the speaker and the Bluetooth device. For instructions on how to pair the speaker with the Bluetooth device, go to the product's support site to view the relevant knowledgebase article.
    5. To further isolate, try pairing the speaker with other Bluetooth device.
  4. If the issue happens when connecting either on Bluetooth or Aux-in, please contact Creative Customer Support via email.
Note: Creative Bluetooth speakers do not need any driver to operate. You may need to update the Bluetooth driver of your computer's built-in Bluetooth adapter or your USB dongle. To determine whether your computer or USB dongle is updated with the latest Bluetooth driver, please refer to their user's guide or website for information.
http://support.creative.com/kb/ShowArticle.aspx?sid=90429
Jun 05, 2015 | AUVIO Bluetooth Portable Speaker
H70 cant connect with my dell laptop it worked good yesterday maybe I removed something or changed setting
Disable and tenable Bluetooth. Clear past history. Put headset in pairing mode then use computer to search.
mark
motorola support
Aug 31, 2014 | Motorola Mobility H730 Bluetooth Headset
Bluetooth pairs but will not connect
Try pairing and connecting with another headset. Or delete the pairing and pair again.
Mark
Motorola Support
Aug 21, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
I cant pair my iphone with my bti 002 bluetooth stereo transmitter for my car stereo system. any ideas?
I have the same problem. My iphone 3gs doesn't even see the BTI 002. I tried to connect it to my computer (windows 7) and the computer saw it and downloaded a driver for it but it cannot connect to it.
Jan 17, 2010 | Apple iPhone 3G
Bluetooth headset now will not pair up with my LG enV
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Jul 20, 2009 | OEM Systems Motorola Bluetooth Headset...
Bluetooth problems!!!
you need to pair the devices in order to connect and use the bluetooth. Its for security reasons.
once the pairing is done you can use it
to pair go to bluetooth menu then options or configuration >devices>add new
now search everything will be fine
Jul 02, 2009 | HTC G1 Smartphone
Iphone won't work with bluetooth in mazda 3 2010 My iphone shuts off whenI try to use the bluetooth system in my mazda 3
iPhone has had bluetooth since the first model in 2007. With iPhone OS/firmware 3.0 (free for all iPhone users), iPhones are fully A2DP compliant and link with Mazda bluetooth.
My current experience is with a 2010 Mazda3 and iPhone 3GS, where I get phone and iPod functionality via bluetooth (yes, without jailbreaking), though the steering-wheel controls are limited to play/pause and volume only.
Jun 12, 2009 | Apple iPhone 3G
Blueant supertooth not pairing to samsung omnia i900
Hallo Stu,
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Open Questions:
AT&T 8925 Tilt Smartphone Logo
113 people viewed this question
Top AT&T Computers & Internet Experts
Ekse
Vincent G
Vincent G
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
