Question about Palm Tungsten T5 Handheld
My T5 Palm stopped syncing (USB) for no apparent reason....I already deleted all USB hubs and ports (WIN-XPSP2) and reinstalled PALM from scratch...but, nothing...the closest it got was a fast flash (1sec) of the sync screen and gone...
  • 689 Answers
Cable might have connectivity issue you may try wireless sync or you may create new profile and test again
Posted on Aug 23, 2009
SOURCE:
Palm Desktop 6.2 +Hotsync 7
Here is the link to the hp forum that contains a link for the win 7 and 8 drivers. http://h30434.www3.hp.com/t5/Palm-OS-WinMo-Hardware-and-Software/64-Bit-Windows7-8-8-1-USB-drivers-for-Palm-Desktop/td-p/2159769
Aug 12, 2014 | Palm Tungsten E2 Handheld
My T5 will not synch my calendar in Outlook
Welcome to Fixya
Double check the Palm or palmOne program in Windows. Click Start then All Programs then Palm or palmOne. You should see an icon in there called Sync with Outlook or something similar. Click that icon and the Outlook conduits will replace those for Palm Desktop. Some conduits, like Media/Photos will continue to sync with Palm Desktop, but Calendar, Contacts, Tasks, and Memos will sync to Outlook.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Aug 10, 2011 | Palm Tungsten T5 Handheld
Palm set to COM1 not serial connection-won't sync
Normal 0 The best thing to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
Normal 0
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/supportservices/page_en.html
Nov 10, 2009 | Palm Z22 Handheld
Palm z22 usb cable connection problem
I have the same problem, but with TWO z22s. Both are about a week old, and both "talked" seamlessly to the computer. Suddenly neither does. Do not see anything wrong with USB port or cable. Uninstalled all PALM OS from desktop and reinstalled. Still no link.
Aug 22, 2007 | Palm Z22 Handheld
Hotsync problem
With a USB 1.1 machine .. try this ...My work around - disconnect ALL USB devices from the computer, NO multiport hubs, make a direct USB connection to one of the available open ports, then reboot the computer. Upon gaining control, then try to hotsync. If I had any other items connected or ran any other programs prior to hotsync, I was not able to perform a successful hotsync. The qwerks of the T5 and the sync conduits. Hope this helps Bob
Aug 09, 2007 | Palm TX Handheld
Windows XP, Palm m130, & Outlook 2003 - Sync problem
It sounds like the computer is noticing the USB activity (from when you hit the HotSync button) but for some reason it can't find the correct information/driver. I'd first try a soft reset (stick a paper clip or the end of your stylus may screw off to reveal a pin, in the hole at the back of your palm) Don't worry, it won't delete your info UNLESS YOU HOLD DOWN THE POWER BUTTON (SO DON'T). Once it's booted back up, try the hotsync again. If that doesn't work, you may need to find the usb driver for your palm and reinstall it. This could just be copying a file from disc, or reloading your Palm Software. Good luck
Sep 12, 2005 | Palm m130 Handheld
T5 Outlook Calendar Synchronization failed - Any one have a fix?
I went to the MY COMPUTER folder, clicked open PROGRAM FILES, open PALMONE folder, open the username folder and deleted the back-up files. However, before I did this I deleted all of the problems dates in the PC calendar and set the hotsync to PC overrides handheld. While this works, unfortunately I have found that I need to do it every once in a while which is very disappointing. It seems that Windows does not operate seamlessly with the Palm T5. I find that the hotsync crashes 50% of the time forcing me to reset my Palm T5. No information is lost, but it is really a pain in the *** to have to do so often. Versamail hotsync sometimes freezes on the handheld, but that is another issue which I have managed to fix much in the same way as describe above.
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Synch problem after installation
If your cradle is connected to a serial port, you will need to ensure that HotSync Manager is configured to use Serial Ports. To do this, follow these steps: 1. Click the HotSync Manager icon in the Windows system tray. 2. If there is a check mark next to the 'Local Serial' menu item, then you are already configured. 3. If there is not a check mark, click the 'Local Serial' option. For more information, refer to the handbook that came with your handheld. If you did not uninstall your previous version of Palm Desktop, the configuration will be done automatically.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Open Questions:
Palm Tungsten T5 Handheld Logo
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
