Question about GoVideo Go Video DVD/VCR Combo
The DVD drawer will not open - GoVideo Go Video DVD/VCR Combo
HI MELVA,
REGARDING YOUR NOT BEING ABLE TO OPEN YOUR DVD DRAWER. I JUST POSTED THAT PROBLEM FOR MYSELF ON 3-2-09!! ONE SUGGESTION I RECEIVED WAS TO TRY A PAPER CLIP!! I KNOW THAT SOUND CRAZY BUT IT DID WORK FOR ME!!
OPEN ONE END OF A LARGE PAPER CLIP, THEN PUSH THE OPEN BUTTON AND WHILE IT SAYS OPEN I PUT THE LENGTH OF THE PAPERCLIP TO THE UNDERSIDE AND TO THE RIGHT AND I EVENTUALLY HIT SOMETHING THERE THAT OPENED THE DRAWER AND NOW IT OPENS AND CLOSES ALL THE TIME!! PLEASE TRY BEFORE HAVING TO BUY ANOTHER UNIT!!
ANN MARIE
Posted on Mar 03, 2009
I have the same problem. Best way to open the door is to hit the eject button and then bang lightly on the door using the remote controller. Works every time.
Posted on Apr 15, 2008
The DVD drawer will not open. I have spoken with other people and it appears it is broken. A new DVD player will have to be purchased. Too bad, I haven't owned this for very long and don't use it very often so I'm sure I will look for another brand.
Posted on Apr 07, 2008
Magnavox ZV457MG9 A DVD drawer won't open
one of the faults with the home dvd player it seems we have to open them to remove the stuck dvd .and more often than not we end up braekingthe danged thing anyway
Mar 15, 2015 | Magnavox Televison & Video
This is a dvd recorder for a tv the door door to yhe dvd will not open
sounds like something has jammed in the drawer track
on the front of the drive is a very small hole
that is the manual open override
use a paperclip and push it into the hole as far as needed until the drawer opens
then slowly open the drawer by hand
look on both sides of the drawer to make sure there is no dirt or other foreign matter in the tracks where the drawer opens
Dec 16, 2010 | Lite On LiteOn 16X Dual Layer DVD...
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
I have a DVD that is stuck in my TIVO. The screen
Take the DVD player aparts,take out DVD disc out of the drawer,check the open/close drawer button again.Same result indication on the screen say is open infact it close.The motor the help open and the dvd drawer it dead.Need the motor replaced.
Jun 26, 2010 | Humax T800 TiVo 80-Hours Video Recorder
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
When dvd is inserted "read" comes up on screen on
Not a lot to go on...
I would expect the unit says read for a while, then opens the drawer. This is an optic issue. Optics are $$$. If the drawer opens almost immediately, it is likely the drive's drawer sense switch needs cleaning.
Mar 29, 2010 | Zenith XBR716
The dvd drawer will not open on Bose 3-2-1 system. When you push the button to open the dvd, the display say ''opening'' but it does not open. There currently is a dvd inside.
That happens when you close the drawer instead of pressing the close button  you can skip gears and it would have to be taken apart and re-calibrated.   Sometimes it is just a glitch that you can over-ride using a straight pin into a small hole on the front  (assuming this uses a drawer).
Nov 09, 2009 | Audio Players & Recorders
The DVD drawer will not open on the model TT 320
Hi
Thanks for using FixYa. Please locate the DVD player’s manual eject button which is a small hole located underneath the DVD drawer. Now insert a stiff wire like a paperclip or safety pin into the hole and push gently to open the drawer. Now pull the drawer gently to open it. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling then you need to remove the label. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player and you need to have it serviced.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | TruTech TT320
THE DVD DRAWER WILL NOT OPEN!!
Try using paper clip to open your dvd drawer.
Mar 03, 2009 | GoVideo Go Video DVD/VCR Combo
My DVD Drawer will not open on my Gateway Laptop
My dvd drawer will not open on my
Gateway Laptop
Nov 29, 2008 | Gateway AR-230 DVD Recorder
GoVideo Go Video DVD/VCR Combo Logo
228 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
