Question about Jenn-Air JCD2295HES Side by Side Refrigerator
Jenn-air JFC2089HES french door
No water from interior water filter. We replaced the filter still no water
  • tracy7375 Apr 01, 2008
    where is it located and how do you fix it
    thanks
  • Jenn-Air Master
  • 19,396 Answers
The relay valve that controls the water is stuck.
likely hard water deposits, otherwise the water solenoid is not working
Posted on Mar 31, 2008
  • 2,323 Answers
Check the water hose and make sure is not kinked.
The hose might be frozen as well.
  • Jaime Hernandez Mar 31, 2008
    You will find more info in here.
  • Jaime Hernandez Apr 01, 2008
    Check the picture from this site and click on the picture, point to where you see the parts to know the location and illustrations.
Jenn Air JFC2089HES Frig and Freezer not working.
Up is up and down is down......
What numbers is it changing back to? If you hear a fan that is good. Do you hear any 'clicking' by chance?
It is possible that for this, you may have a bad thermistor, but more information and or possibly an error code would help much more.
May 04, 2014 | Jenn-Air JFC2089HE French Door...
Jenn-air model # JFC2089HES...the freezer door will not open at all..please help
Shut the unit off or unplug it. There's probably ice formed inside preventing the door from opening. Is it frozen shut or can you open it a little? If you can open it a little something may have shifted, if so you may need an expert to come out and take a look
Feb 23, 2011 | Jenn-Air JFC2089HE French Door...
I bought a used Jenn Air french door refrigerator model #JFC2089HES, but water will not dispense nor will it make ice. It's hooked up to a cold water supply under the sink which is working.
It sounds to me like you're going to have to do some serious electrical checking. There are two electrical solenoid water control valves right behind of the fiber cover where your water line connects to the refrigerator. One solenoid valve is for the water dispenser and the other is for the ice maker. They are mounted together, side by side, on the same metal mounting plate. You two sets of terminals on each solenoid. one set on each solenoid should be hot (register line voltage) when tested between the terminal and ground. the other set of terminals connect two the switches in the water dispenser and ice maker. If have someone push the dispenser switch while you have your ear close to the solenoids, you should hear a clicking sound. I have never seen both of the solenoid valves go bad at the same time. I believe you have a power supply problem to the solenoid assembly itself.
Mar 16, 2010 | Jenn-Air JFC2089HE French Door...
I want to replace the water filter - what size/type is acceptable on jfc2089hes?
look at old filter and get # off filter and take it to local hard ware store and they will give excat filter or they will have a replacement # Make sure to measure inlet and outlet sizes to in sure proper filter instalation..
Jul 28, 2009 | Jenn-Air JFC2089HE French Door...
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Gone Crazy
you have to adjust door may be is the filter or water valve some time the indicator filter dont come on on till filter singal it
Mar 18, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-Air JFC2089HES Bottom freezer, French door:
You have a control board issue and should call out a tech. to do the repair. If your still with in your 1st year of purchase then Whirlpool should pick up the charges of part and labor. The tech. will need to be Whirlpool warrenty certified.
Feb 26, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
230 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
