Question about Olevia LT42HVi 42 in. LCD Television
Cc on Olevia
Did you ever get your problem solved? We have the same problem and it's driving us crazy!
  • mendi411 Jun 30, 2008
    Same problem. Trying to install on the Comcast master control and cannot do it.
How do I turn off closed caption
Posted on May 13, 2009
    Problem Solver:
  • 7 Answers
Try 004
Posted on Jun 21, 2008
My tv has a mind of its own it keeps changing source and volume by its self there are no batteries in any remote and it is still going crazy
How close is your neighbor? Olevia is a low end tv, meaning they use remote codes that are compatible with other electronics. To isolate this I would find the IR sensor and put a piece of tape over it. Also try closing blinds or shades once this starts to happen. If this solves it I don't know how to tell you to fix it other then try to turn the TV away from the source. If it doesn't fix the problem Unplug the TV from the wall for a half an hour to try and reset the system.
May 25, 2010 | Olevia LT42HVi 42 in. LCD Television
Can't turn closed caption off.
Go in ur tv menu go" Picture" go down to reset, press it the tv will back to factory setting.If the Captioning still there.Than ur Tuner Main signal board have problems.
Apr 04, 2010 | Olevia 237T 37 in. LCD TV
Where do i get olevia 537h firmware
funny things like channels changing of there own accord ,volume going up and down and other strange goings on are usualy down to the batteries in the remote no longer being of full strenght hope this helps
Jun 12, 2009 | Olevia 237T 37 in. LCD TV
How to remove closed captioning
you can either turn it off in the TVs main menu or check for a CC button on your remote.
Feb 02, 2009 | Olevia LT32HVM 32 in. LCD Television
Cc button
Press "cc" again, and that should do the trick...accordianman
May 28, 2008 | Olevia LT32HVE 32 in. LCD Television
27 INCH OLEVIA LCD FLATSCREEN
Access the TV's menu by pressing the "menu" button on the remote. Look for "Captioning" or if not on the screen try "set-up" or "audio" all the while looking for "CC", "Caption" or "Closed Caption".
When you find it, turn it off.
Apr 06, 2008 | Televison & Video
Broken tv
I had problems with channels on my Olevia LCD TV. My problem was solved by updating to the latest firmware.
http://www.olevia.com/en-us/Support/Firmware.aspx
Make sure the USB flash drive is formatted with the right file system, or the set will not see the updated firmware.
Mar 30, 2008 | Olevia LT26HVX 26 in. LCD Television
Jvc flat screen television model AV32F713 Black box on screen.
On the reomte control (bottom) left of the sleep button is a cc button, push that until "OFF" appears on the screen. The close caption box should disappear. It worked for me, finally.
Nov 29, 2007 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I had the same problem....
The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
The CC button should work now.
Sep 07, 2007 | Olevia LT32HVE 32 in. LCD Television
Olevia LT42HVi 42 in. LCD Television Logo
80 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
