Clock setting on digifusion pvrt95
Having just changed over to british summer time my digifusion pvrt95 freeview box has not advanced 1hour, it is 1 hour behind, much to my annoyance...
i have unplugged the machine overnight,
i have done a full factory reset,
i have retuned all channels
i have looked for new download upgrades
but i still cannot alter the clock in anyway???????
please can you help!!!!!!!!!!!!!!
  • digifusion Apr 02, 2008
    Exactly the same - clock 1 hr behind and no power on earth corrects it!
  • 537 Answers
Check your users manual for your digifusion pvrt95. It is not an issue with the hard drive.
Posted on Apr 09, 2008
Tip
How to set the time/date (you have to do them both together)
To set the time and date (you have to do them both together):
  • First press and hold the 'CLOCK' button until it beeps then let go.
  • You will then be required to select the year by scrolling up or down with the 'TIME SET' rocker switch on the right hand side.
  • Once you have the right time, press the 'ENTER' button, to the right of the rocker switch once.
  • You will then be required to select the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
  • You will need to repeat this to select the date (day).
  • You then use this same process to select the time, starting with the hour and then the minute.
  • After you have finished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
REMEMBER to press the 'ENTER' button after selecting each thing to move you on to the next thing to set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from British summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on British summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
on May 23, 2009 | Sony ICF-C273 Clock Radio
Tip
How to set the time and date (you have to do them both together)
  • You will then be required to select the the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
  • After you have finnished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from british summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on british summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
Clock change to british summer time on kndle fire hd
To change the timezone.
Step 1: Pull down the upper status bar, More +
Step 2: Select Date and Time
Step 3: Select Timezone - change to the correct Timezone
Mar 31, 2013 | Amazon Kindle Fire HD
How to change clock on a kindle fire to british summer time
Step 1: Pull Down upper Status Bar - More +
Step 3: Select Change Timezone
Step 4: Change to your preferred Timezone (British Summer Time is +1 GMT)
NO INSTRUCTIONS ON SETTING CLOCK
Good Luck x
Apr 11, 2009 | Sony ICF-C273 Clock Radio
How do you set the time
Good Luck x
Apr 04, 2009 | Sony ICF-C273 Clock Radio
My Sony ICF - C273L
Im sorry i have no idea where to get hold of a manual but i thought this might be useful until you find a manual. I hope you find one soon x
Good Luck x
Jul 30, 2008 | Sony ICF-C273 Clock Radio
Need operating instruction
I dont know where to find an instructions booklet but I can help with setting the time/date:
Good Luck x
Mar 16, 2008 | Sony ICF-C273 Clock Radio
Computers & Internet Logo
109 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
