Question about Brother HL-2040 Laser Printer
Paper stuck in roller
Is it possibel to remove roller? I have a peper jam and cannot reach the paper in the roller
Please help!
  • navila Mar 31, 2008
    Does anyone know if I can remove the paper roller from printer Brother HL-2040?? I have a paper jam, cannot see the or reach the paper...think it's stuck in the roller
    Please help!
    Problem Solver:
  • 7 Answers
Dear Navila,
Please ensure that you have check that there is no paper inside the toner and drum area accessible from the front.
Also check that there is no paper stuck below the bottom paper tray which you need to take out the paper tray.
Last you need check the rear cover for any paper visible.
If the problem persist you need to clean up the fuser assembly.
To take it our, you need to do the following:-
1) remove the rear cover
2) remove the side cover
3) remove the top cover
4) remove the black paper guide at the back of the printer
5) remove the white paper guide at the top of the fuser assembly.
6) remove the fuser assembly (2 screws) and the cables white cable on one side and grey cable attaching to the other side of the fuser assembly.
7) Clean the fuser assembly.
8) reinstalled them.
Taking out the paper guide cover is tricky since you need to take them out at a certain angle.
chekamal
Posted on May 12, 2008
    New Friend:
  • 159 Answers
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the control panel button.
Posted on Apr 02, 2008
SOURCE:
HP LJ 4L paper jam light flashes indicating a peper jam after printer makes a grinding noise. What can be the problem?
You may be right about the worn gear as a factor but I used to have a LJ 4 and whenever it indicated a paper jam it was always right. In some cases, the jam was a tiny scrap of paper deep inside. It took a flashlight and examination of every bit of the paper path to find it
Nov 02, 2012 | HP Black Toner for LJ4L & 4P
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
When I went to run the copy machine this morning it jammed. The paper jammed where it grabs the paper. I removed the drawer and got the paper out. Put the drawer back in the machine and it was fine. I...
This could be a faulty sensor, but as a no cost option it could also be a worn pickup roller.. just try to roughen it with some sandpaper... see if that helps..
Apr 19, 2017 | Canon imageRUNNER 210S Copier
Continuous Paper Jam
Could try cleaning the peper feed rollers, may be debris on the feeders. Possibly could be damaged..
Rich
Aug 13, 2009 | Canon LaserBase MF5750 All-In-One Printer
Hp deskjet 6122 paper feed
Try putting Isopropyl alcohol on the feed rollers. These rollers become hard and smooth with time and cause all sorts of paper feed problems. You can find isopropyl alcohol at any drug store(it is rubbing alcohol).
Aug 10, 2009 | HP DeskJet 6122 InkJet Printer
Printer canon mf 5750 thankyou verymuch
please chack your paper feed sensor i guss it was broken
Aug 04, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Paper jam
IS IT THE PAPER JAM LIGHT? LOOK IN THE PART WHERE THE PAPER COMES OUT OF THE MACHINE IN THE CAVITY ON THE LEFT SIDE FIND THE EXIT ROLLERS IS THERE ANY PAPER THERE? PULL OUT YOUR PAPER CASSETTE ALL THE WAY LOOK IN THAT CAVITY. OPEN THE RIGHT HAND DOOR THERE IS A GREEN ARROW THAT MOVES THE GATE LOOKIN THAT AREA. HOPE THIS HELPS IF THESE DO NOT FIX YOUR PROBLEM YOU NEED A TECH TO LOOK AT IT.
Dec 31, 2008 | Sharp AL 1631 Copier
Paper jamed or wrinkled
Dear
this is the problem of hot roller replace it paper jam problem will be resolved.
Nov 25, 2008 | Samsung ML2251N Laser Printer
Printer will not catch paper in tray
The rollers need to be clean or replaced.
Feb 04, 2008 | Dell M5200n Laser Printer
Brother HL-2040 Laser Printer Logo
364 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
