Question about Car Audio & Video
AMPLIFER CHECK IT WHEN OUT SIDE OF CAR
A400HLF JENSEN,WANT TO MAKE SURE IT BEFORE INSTALLING.
    Novelist:
  • 100 Answers
Depending on what you have on hand I could tell you how to check if it works or not. If you have a power supply that has significant amperage output. Probably greater than 10 Amps then I would use that because of the ability to current limit so if there is something wrong you wont hurt anything too bad. Otherwise, use a car battery and hook them into Ground and Battery connections also, hook the Remote and Battery together so that the amp will turn on. Then get an audio source to plug into the RCA input jacks. Then use a speaker to test each output. I hope it helps.
-Andrew Hawkins
Posted on Apr 01, 2008
SOURCE:
I'm installing a Jensen vm9224bt in a 04 ford f150
I have an 05. The extra plug from the factory harness is for the steering wheel controls. Leave it unplugged. I just installed the same stereo.
Dec 17, 2011 | Jensen Car Audio & Video
12 volts to amp, when connected no volts, it turns on in my friends car.
The ampliflier require an amount to power volts to perfrom. You friends car may have a power stabilier installed to produce appropiaet supply to stereo systesm. usually, a direct wire from the engine to the amplifer may least function as manufacturers default specifcation. If the amplifer performs at all, a fuse is blown to protect the devices in wiring cuircuits. if the device functioned in another car, it is not damaged. Consult with an auto electrician to attain appropiate wirign or acqurire the component parts to wire the vehicle. Important notes. Each device usually will have an instruction on installing. However, the power source from engine depending on type of vehicle may require regulators to share the current to stereos amplifiers and speakers.
Jan 29, 2011 | Clarion APA450 Car Audio Amplifier
Amplifier making engine noise
make sure the remote and power wires are ran on the opposite side of the car from the audio hook ups
Jul 10, 2010 | Jensen PS2180 Car Audio Amplifier
Clarion stereo in1997 mercury marquis wiring hook up to amplifer
make sure the speaker wires in the car do not have one side grounded.the output on the clarion is a floating output and cannot be grounded.the best solution is to look at the wiring on each of the speakers,and match them out to the ones on the clarion.the most common colr code is white front left,gray front right green rear left and purple rear right.each speaker has a plus and minus.mixing them up will result in the speakers being out of phase and result in poor bass performance.i would wire the wires directly to the clarion using crimp connectors.the first thing i would do is power up the stereo out of the car to 12 volts,and using a speaker make sure you have sound coming out.the yellow wire which is the clock/memory is a must to be connected to constant 12 volts or no sound can result
May 26, 2009 | 1997 Mercury Grand Marquis
Bypass brake code VM9311YTS
just connect the pink wire to the ground wire. some will tell you that a menu will pop up if so just input the numbers 5,4,3,2,1,0 make sure you hear a beep after every number. the menu will look like a hammer icon. im not sure if you have to input the code because i didnt need to
Apr 01, 2009 | Jensen VM9020TS Car DVD Player
Amplifer
recheck your ground make sure it has a good connection most of the time this is what it is
Feb 11, 2008 | Autotek SS290.2 Car Audio Amplifier
Sound problem
sounds like you have the antenna wire connected to the power amplifer lead in the car.
Go behind the radio, there is a solid blue wire that will be connected to a wire in the car, take the solid blue wire off, and connect the blue/white from the radio to where the solid blue was originally connected. This should solve your problem
Nov 24, 2007 | Jensen VM9410 Car DVD Player
Need board map!
You might write to the folks at http://stereomanuals.com and see if they can cover your model. I know they do have some Jensen manuals. Hope you succeed.
Mar 16, 2007 | Jensen LXA300 Car Audio Amplifier
Jensen JPX680
Check Jensens website...
Mar 03, 2007 | Jensen JXP680 Car Audio Amplifier
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
