Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80 Memory Card Not Not Reading.
I insert my memory card that I have been using fine for the past 6 months. But today, I try to insert the card into the camera slot and display says "No Card Present" when there is indeed a card in there. I think the problem is that the card is not actually being pressed all the way into the memory card holder, because when I manually press the card down, the display tells me I have so many photos left available. Any ideas as to what is the problem?
  • Mike Johnson
    Mike Johnson May 11, 2010
    does the card eject fine? first lets try a easy possible fix take a pencil eraser and scrub the memory card contacts they might be dirty if that does not work then the problems are the memory card pins. A bit of work but it is a pretty easy fix. once the camera back is taken off you then have access to the memory card pins they need to be lifted back up so that they can press agenst the memory card. hope this helps
  • 58 Answers
I would try another card first, before doing anything else.  If you have been using just one card for 6 months and using it a lot, it could be corrupted.   It's best to always have a back up of at least one card anyway, and they have come down in price considerably.
If my suggestion and McComijohns's don't work, I would consider taking the camera in for repair.   It is NOT a good idea to mess around too much with the inner workings of the camera.  You could cause a lot of damage and it won't be covered under your warranty.  Good luck.
Posted on May 11, 2008
When I zoom my nikon D80 to take picture, the apperture display will read F---- as a result, the image will be dark.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 10, 2011 | Nikon D80 Digital Camera with 18-135mm...
My Nikon D80 shows an ERR, what should I do? FYI...I tried turning the camra on, removing the battery and pressing the shutter button for 30 seconds. That didn't work.
It's possible that you need to format the memory card. Formatting is found in the camera set up menu scroll down to "Format Memory Card" and follow on screen instructions.
Formatting should be done after each time you download pictures to your computer. Not delete, as delete does leave some data behind and eventually clogs the memory card so new data can not be placed on it. Another possibility is that the card somehow has become locked I'll include a diagram. Also a new card needs to be formatted to the cameratri3mast_228.jpg it is going to be used in.
Diagram
Jan 27, 2011 | Nikon D80 Digital Camera with 18-135mm...
My d80 cameras memory card locked automatically when i insert in
it has a write proctect tab on the on the side of the card when its down the card will be locked ,slide it up to remove the lock.hope this helps pls do let me know
Jun 06, 2010 | Nikon D80 Digital Camera with 18-135mm...
Card Cant Be Read
Same thing happened to me, after taking some pictures of a christening, connected to card reader, it wasn't recognised by card reader. I re-inserted it in camera and got card error, tried some softwares to extract pics but for nothing!!! I'm very dissatasfied!!
May 25, 2010 | SanDisk Ultra II 8GB Secure Digital High...
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
My computer is not reading the memory card. Nikon D80
If you are using a 4GB or higher SD card, some computers cannot read it directly from their in-built SD reader. Buy an external card reader and plug it in. Your computer should now be able to read cards 4GB and larger
Oct 07, 2009 | Nikon D80 Digital Camera with 18-135mm...
Problem when i insert my 4GB SDHC card in Nikon s550
you should try formatting the memory card to something different. because the same problem happend on my psp.
Aug 14, 2009 | PNY 4GB Secure Digital High Capacity...
My Nikon D80 flashes "off" or error and won't take a picture
Is the battery charged?
Do you have a memory card in the camera?
Is the card empty?
Is the lock on the memory card off?
Jul 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Dear taran_2005, Thanks for your reply to resolve the issue. After sending you my issue regarding Nikon Camera D80, I formated the card. All snaps were deleted as expecter. Display "No Memory Card? and...
Please make sure your memory card does not have the "Lock" setting clicked on. It is a small slider at the side of the card. Check this out and try to save again to your card.
Jun 09, 2009 | Nikon D80 Body Only Digital Camera
Problem in reading memory cards of NIKON D80
Some notebooks cannot read SD capacities of 4GB and above. The workaround is to use an external SD card reader.
NOTE: Please rate our help to keep this free service online
Apr 22, 2009 | Nikon Coolpix 5700 Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
