Question about Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive
Light doesn't turn blue at all
I've had this hard drive for a while, and it was working fine.
I tried to access the hard drive, but for some reason, the light does not turn blue at all (it stays red). I tried restarting the computer, hard drive, connecting it to a different USB port, connecting it with a different USB cable that I know for sure is working. Nothing seems to work.
The last time I was able to access it, my husband told me that the hard drive was on (although I'm sure I had turned it off) so he turned the switch off on the back. But next morning, I noticed that the hard drive light was still blue, so I flipped the switch again, but the light was still on and blue.
So I disconnected the USB cable and power cord to make sure it's turned off. After that when I tried to access my hard drive, the light won't turn blue.
  • denimbird Jan 14, 2009
    My acmdata drive suddenly disappeared from my list of drives and the light won't turn solid blue - it flashes blue from red. I have tried it on various computers, disconnected and reconnected cords and ports. Is there any solution or hope???
    Problem Solver:
  • 7 Answers
Plug it into another computer if possible, clear ALL files on it.
You must of been sending something to it when you flicked the switch, they would normally go off straight away.
(Backup on the other computer first)
If this does not work then you may want to see if you can see a usb stick in your USB ports. If you can it's a fault with the harddrive, nothing else you can do.
Posted on Jan 14, 2009
I have a seagate barracuda 7200.2 and a i/o magic usb hard drive enclosure. it runs fine blue light comes on but,.....it doesn't show up on comp.
Have you tried the hard drive outside of the enclosure? Maybe it just isn't compatible with it. Else something with the connector could be broken
Jan 06, 2013 | Computers & Internet
Stop error on sony vaio vgn-nw235f
There are multiple possible reasons for your problem:
1. virus
2. hard-drive malfunctions
3. OS malfunctions
4. memory failure
Try to install an antivirus and do a deep scan. You should pay attention to a boot sector virus.
If this doesn't help, do a back-up of your data, format your hard disk and re-install a fresh OS.
If this doesn't help either, try changing the RAM memory.
If that doesn't help either, it means your hard disk's boot sector is damaged. There are solutions for this too, but I think there is a big chance you won't get to this point.
Aug 07, 2012 | Sony NW Series VAIO VGN-NW235F PC Notebook
I have the SimpleTech Pininfarina 320GB Hard Drive and was working great for a while. Then all of the suddent it just stoppped working. The light doesn't come on anymore on the unit. I've tried...
Hi Angela ,
You' re probably facing a power or usb issue . Consider opening the enclosure ( will be lost , i presume ) and placing the drive in an external usb box ( available in any computer store starting from 20 $ ) to be reconnected to your pc . If this doesn' t help , it means your device is dead . There then still is a small opportunity to recover the lost data by using a recovery software like Recuva ( free ) or TenorShare Recovery ( payable ) .
This should help you solving your issue .
Best regards ,
fanaudi .
Sep 28, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I've had my WDBAAF0015HBK My Book for a few months, but now I have a new computer and went to attach it but it doesn't register. I can't hear anything whirring around inside it, but the front...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jun 20, 2011 | Western Digital My Book Essential...
Drive Being Recognized as Removable Disk
Same issue with my 500 GB TFD500U16. A little more description is that my PC is detecting the power when turning on the drive and the HDD itself is spinning up. Also the Blue light that normally indicates HDD activity by turning Red no longer shows activity but just stays Blue. This indicates that the data side of the HDD is not seated properly. Since mine is out of Warranty, I took it apart and found this to be the exact case.
! ! ! ! Please perform this at your own risk ! ! ! ! Especially if your warranty is still in effect! ! ! By loosening the HDD mounting screws inside that will allow the connection to seat properly and data to be seen.
Dec 16, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Drive Not Ready
typical of external drives overheating.
i sell external case with fan at my store.
Nov 03, 2007 | Fantom Titanium Hard Drive
Acomdata (HD320UFAPE5-72) (HD320UFAPE572) 320 GB Hard Drive Logo
280 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
