Question about JVC AV-32F704 32" TV
25 inch sanyo tv
Hi, my 25inch Sanyo tv, color is fading the picture looks blury and there are horizontal lines that are going across the screen. I only had the tv for 2 1/2 years, can you tell me what the problem is and if I need to save some money to buy another tv before this one goes completely out?
    Sergeant:
  • 308 Answers
If the horizontal lines going through the picture are fine white lines, then I would suspect the picture tube as having a heater to cathode short or some other problem. Since some sets have had a 3 year warranty on the picture tube, you may be lucky unless the labor to replace the tube is more than the set is worth. Sanyo is usually not a good name in consumer electronics anymore, so if you're looking for a replacement I would look elsewhere.
Posted on Apr 03, 2008
SOURCE:
Why has my sanyo flat screen television only got coloured horizontal lines across the screen?
That might be an issue with the TVs picture tube if it was not one of the LED or LCD TVs. Please get a technician changed it. If it was any one of the LCD or LED TVs, then it would be more expensive than you expect.
Jul 20, 2014 | Sanyo Televison & Video
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
32 ''Sanyo DP32648 TV has horizontal line running across screen
If you do not have any bad capacitors Problem will be the Display Panel
Call Encompass Parts Distribution or visit their website and type in your Model number 1-800-638-3328
Apr 28, 2010 | Sanyo Televison & Video
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
No picture on screen
No,Ur vertical/horizontal IC is shorted or cold soldiers.Could be the parts that support the IC is also.
Aug 19, 2009 | Sanyo DS27820 27" TV
Picture tube
no you have no vertical bad chip ic
Oct 21, 2008 | Sanyo DS27820 27" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Sanyo ds 25500 Television
No, you have either a bad solder connection on or near your vertical output IC, or a defective IC itself. Don't leave the set on for long with the line across the screen or your pic tube will be toast.
Mar 05, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
SANYO 37 INCH TV
Check for cold or crystalized solder joints on the board that is connected to the CRT.
I would also check the solder joints around the high power resistors near or around the horizontal section.
Good Luck.
Oct 13, 2007 | Sanyo AVM-3659S 36" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
JVC AV-32F704 32" TV Logo
244 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
